engine complete, need help starting.
Old Nov 10, 2007 | 04:35 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
Default engine complete, need help starting.
ok now i have the engine completely together, all vac lines hooked up, all electrical connection hooked up....so thats all good
so i tried starting for the first time and it wouldnt, come to find out somehow i was 3/4 off on the dizzy. so i restabbed the dizzy at the number one TDC dizzy exactly on its spot. now the car starts....but for 2 seconds. it will start and rev itself up to about 3k RPMS and then shut off. no backfires or anything, it actually sounds really healthy. i've even tried starting it and turning the dizzy to keep it alive but same symptoms.....is this "one tooth off" or do i just not have something right?
i did prime the oil pump, new plugs, cap, rotor, wires. there is obviously spark and fuel because it starts. it actually starts at the flick of the key, it doesnt have to continuously turn over, its just turns and starts right away.
Old Nov 10, 2007 | 04:51 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: engine complete, need help starting.
if you had the battery disconnected for any length of time which I assume you probably did..you'll need to give the ecm a little time to relearn all of it KAM functions/ adaptive learning strategies...the KAM is the keep alive memory where all actual running values are learned and or stored like idle speed
Old Nov 10, 2007 | 04:54 PM
FivePointOhh
in limbo
how long does this take? do you think thats all thats wrong?
Old Nov 10, 2007 | 05:01 PM
mjr46's Avatar
mjr46
just follow the idle relean procedure you'll have to let it learn the idle sitting still and then with all accessories on put follow the instructions in the stickys...if it ran fine before and you had the battery disconnected that's most likely the issue...you'll also have to drive it around a little because it'll have to relearn all adaptive strategies again...disconnecting the battery resets the ecm/kam
Old Nov 10, 2007 | 05:10 PM
ALMOST STOCK's Avatar
ALMOST STOCK
I had the exact same symptoms with mine revving to 3K for a split second and then dying and I found that that PVC valve had come out of the rubber grommet.
Old Nov 10, 2007 | 08:25 PM
jagman454's Avatar
jagman454
You set yours to 0 at TDC right?I believe I had the same problem you are having, I just finished my engine like a week ago and I set it on TDC and everything, but it wouldnt run right, then my friend came over and advnaced the timing to 8 and it started right up.
Old Nov 10, 2007 | 09:18 PM
FivePointOhh
in limbo
ok i got it running about40 minutes after i made this post. started up great and sounds good. cant wait to finish tuning it tomorrow and drive it around. thanks guys!
Old Nov 10, 2007 | 09:24 PM
mjr46's Avatar
mjr46
ORIGINAL: FivePointOhh
so what was the problem and fix?????
Old Nov 10, 2007 | 11:38 PM
ALMOST STOCK
ORIGINAL: mjr46
I'd like to know also.
Subscribing!!
Old Nov 11, 2007 | 01:41 AM
getafewlives's Avatar
getafewlives
Geez, way to leave us hanging here!
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
msavoia23
12
Jul 7, 2018 12:08 PM
mdj89
Sep 6, 2015 11:08 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
