rebuilt engine?
Old Mar 4, 2005 | 12:06 AM
spedfarmr's Avatar
spedfarmr
Default rebuilt engine?
I have 130k on my engine and im wondering if i put gt40 heads or trickflow heads and cams if that will be like a rebuilt engine
Old Mar 4, 2005 | 12:53 AM
redsaleen's Avatar
redsaleen
Default RE: rebuilt engine?
I don't know about it being considered a complete rebuild i guess it depends on the wear on the pistons etc..once you remove the heads check em out.I just replaced my heads, intake ,cam,tb,underdrivepullies,installed msd blaster coil,msd digital-6,3.73s,fuel pump,cia,al drive shaft,nx nos,weld skinnies ,weld pro star w/28.5 x 10.5 mt street slicks etcc..the pistons looked brand new in my 95 cobra 5.0.with 88k on it.The heads are trick flow tw,and tf intakes made a big difference.trickflow stage1 cam nice little lope
Old Mar 4, 2005 | 12:57 AM
import slayer's Avatar
import slayer
Not really....what about the piston rings? There's no sense in getting new heads and cam if cylinder compression is low and allowing blowby or the rod/main bearings are almost down to the brass.
Do it right and rebuild the entire engine.
Nick Oliver
Oct 17, 2018 04:22 AM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Luke9222
Sep 4, 2015 06:46 AM
