IS THIS POSSIBLE??
Old Nov 17, 2007 | 06:28 PM
03sixbanger's Avatar
03sixbanger
Ryan's Backup Mod
Default IS THIS POSSIBLE??
I just blew up my 4.2 stroker so im thinking about doing something even more unique. I was thinking about putting our 95 built 302 in my car.....Is is possible??
Old Nov 17, 2007 | 06:42 PM
Streetracer911's Avatar
Streetracer911
Default RE: IS THIS POSSIBLE??
anything is possible with enough work/time/MONEY
Old Nov 17, 2007 | 06:57 PM
03sixbanger
Ryan's Backup Mod
lol i like how you made the edit to add MONEY....i have both cars so it should be too costly.......but what all would have to be swapped....and will an 03 auto tranny work with the 95 motor?
Old Nov 17, 2007 | 07:05 PM
1fstlx's Avatar
1fstlx
it is possible. since you say you have both cars, youll need to swap the k member, engine wiring harness and computer and transmission. hence a newer v6 trans will not bolt up to a 302 much less handle the power. you might also have to toy with the dash wiring harness to get everything to work correctly. (namely instrument cluster)
Old Nov 17, 2007 | 07:09 PM
03sixbanger
Ryan's Backup Mod
ok well thats no problem either. i can get another tranny easily....but i bought a stall for mine. it said for 4r70w or aode. so will it still work in the other tranny??
Old Nov 17, 2007 | 07:15 PM
03sixbanger
Ryan's Backup Mod
and as far as instrumnet cluster, couldn't i just put the v8 one in??
Old Nov 17, 2007 | 07:17 PM
1fstlx's Avatar
1fstlx
i dont think so because v6 and v8 bellhousings are totally different sizes. even though aode came in 95 5.0, i would be on the safeside and get a torque converter for a 95 5.0.
Old Nov 17, 2007 | 07:28 PM
03sixbanger
Ryan's Backup Mod
well me and one of my buddies are going to be workin on it and the only thing he isnt sure of is the instrument cluster. he said he doesnt know if the v6 one will work with the 5.0 computer. but i cant just swap the over cuz the plugs are different.
Old Nov 17, 2007 | 07:44 PM
1fstlx's Avatar
1fstlx
you could but youll lose the electric speedo associated with the v6. the cluster will fit since they are the same dashboard. if ur car is equipped with pats (passive anti theft system) it may or may not start. the cluster from a 95 is still mechanical so youll need the speedo cable as well.
Old Nov 18, 2007 | 12:21 AM
03sixbanger
Ryan's Backup Mod
so there is no way to make the 6er cluster work?
