65mm and 70mm difference
Old Nov 18, 2007 | 01:55 PM
w8less's Avatar
w8less
Default RE: 65mm and 70mm difference
but why not have the max airflow you can have going into the motor? if anything is going to restrict airflow it will be the intake and heads......correct?
Old Nov 18, 2007 | 02:03 PM
Hamutoff's Avatar
Hamutoff
ORIGINAL: Joel5.0
ORIGINAL: stangman94
5mm is the difference. If you put to big of one on it will hurt you on the low end of the rpm range
Why?.......
I believe that too large of a TB for an application... will hurt low end because the airflow will be sluggish thru it compared to the "breathing capacity" of the engine
have a cigeratte smoker blow thru a straw at a friends face
have a cigeratte smoker blow thru a 3" dia pvc tube at a friends face
if you had Lance Armstrong blow thru the straw his ability would not be realized -- he can produce much more flow - he is a 347 or the like he might want to use the 3" pipe....however he would still produce good pressure BUT limited flow w/ straw
lets say that the smokers velocity of air thru the straw was exactly the same as L.A. thru the 3" pipe,
so then straw might fit stock 5.0 but 3' pipe might fit 347....
The 347 would idle just fine with the 3" but be choked with the straw (but still idle just fine)
the stock would idle just fine with the straw but idle poorly with the 3"
Old Nov 18, 2007 | 02:07 PM
w8less's Avatar
w8less
sounds like it would need to be tuned for the increased airflow correct?
Old Nov 18, 2007 | 02:16 PM
Hamutoff's Avatar
Hamutoff
ORIGINAL: Jasperstang308
no. lets imagine extremes for the moment. this always allows me to visualize things. if you had a 3foot MAF and 3foot TB on a reg engine, you could imagine that all finesse would be lost.... its about resoluton here....
the angle of the tb blade would stay the same at the same foot to pedal movements but that same angle would allow much more air into the engine. you would loose fine control
same thing with fuel injectors, too bit and you cant control them at low engine speeds you dont have the fine tiny ajustments at very low output....
Old Nov 18, 2007 | 04:02 PM
Joel5.0's Avatar
Joel5.0
.... I guess a few of the setups I've worked, including a 100% stock SD '86 with an AOD on which I installed a 80mm TB, were exceptions to the "rule" then. Keep in mind that EFI deals with dry air flow, as opposed to a carburetor setup, where the restriction is a must.
Old Nov 18, 2007 | 04:49 PM
93 LX FiveO's Avatar
93 LX FiveO
i put a 65mm tb and 75mm maf on my car with a bbk cai
all were put on separately, at different times.
the tb was last to be installed, and it made a noticable difference throughout all rpm's
Old Nov 18, 2007 | 05:47 PM
Hamutoff's Avatar
Hamutoff
yup I would imagine that would be a perfect mod for even a stock car, if you kept stock maf and 80 mm tb I would guess not work as good
ORIGINAL: 93 LX FiveO
Old Nov 18, 2007 | 05:51 PM
Hamutoff's Avatar
Hamutoff
well that still fits the formula as Ive stated: less restrictive, more restrictive, less restrictive; like so: >-<
which you've followed in your 'stock 86' as stated.
you did not state, however, how they were exceptions; are you saying that you had better off-idle response and fuel economy?
I do not propose a "rule" in any case, just general practice, concept, understanding
ORIGINAL: Joel5.0
Old Nov 18, 2007 | 06:43 PM
93 LX FiveO
first pass with the tb swap (with maf+cai) car dropped 3 tenths in 1/4 mile
Old Nov 19, 2007 | 01:05 PM
Hamutoff's Avatar
Hamutoff
ORIGINAL: Joel5.0
http://www.amazon.com/gp/reader/0760...51983-9707811#
Steve Turners book, page 26
...installing too large an oversized throttle body can hurt performance, particularluy torque
...this is mostly true regarding (page 27) naturally aspirated 5.0's.... torque loss
...tb shouldnt be larger than your maf... you want to create a funnel for the air...
[IMG]local://upfiles/84695/DAC7EE0E5E254B019534F628A9093669.gif[/IMG]
