E303....problems?
Old Nov 18, 2007 | 02:08 PM
95stang50's Avatar
95stang50
Default E303....problems?
will the E303 cam make problems for my sn95 and if so what kind? like what symptoms will my car have from the cam? i heard of vaccum problems but what will the car act like?
Old Nov 18, 2007 | 03:32 PM
saocore88's Avatar
saocore88
Default RE: E303....problems?
i have E303 cams and it seems to make my car idle rough.
Old Nov 18, 2007 | 06:39 PM
95stang50's Avatar
95stang50
ha yeah mine idles rough too but i think thats just the cam.....i meant like any other problems with the sn95 because i heard everyone goes to a steeda19 so i didnt know why they got for that instead
Old Nov 18, 2007 | 07:51 PM
dimebag's Avatar
dimebag
im not an sn guy by anymeans, hell im not even a mass air guy,i do the whole speed density thing. one thing i can tell you though, if you are having issues because of the cam you can always swap to a foxbody ecu...their usually for sale... it doesnt HAVE to be the wonderful a9l....
Old Nov 18, 2007 | 08:19 PM
Joel5.0's Avatar
Joel5.0
If you have an E-303 installed, 110 LSA, 220 duration.... it will make the engine idle a little rough, fox, SN95 or carb....... vacuum @12"-13" Hg..... that's the cam @work........will it benefit from a tune?...... of course!....... is it required to keep a driveable unit?...... nope. Just set it correctly.
Old Nov 18, 2007 | 08:37 PM
vtecwho's Avatar
vtecwho
the E 303 has made myloose tracktion at many times while driving. i believe it is that major cause of a deep lopey idle and the 55hp gain over my previous set up.
you will need a tune to get good benifit from that cam with a A9L ecu. i have heard that the ecu's on the sn95s are a bit different than the fox bodys such as retarding the timing when shifting and such. with that in mind, i have read that people seem go after the steeda 18 cam. i heard its more friendly on the sn95s idle quality.
Old Nov 18, 2007 | 08:46 PM
USMC1775's Avatar
USMC1775
ORIGINAL: saocore88
.....wow maybe you should get that fixed... sounds serious
