AODE problem?
Old Nov 23, 2007 | 07:46 PM
dbiser's Avatar
dbiser
Default AODE problem?
hello guys i have a 95gt with the aode it was rebuilt about 4 years ago with shift kit i think with more or different bands?
The problem is when in high gear and overdrive it stops pulling the engine will rev up like it is in neutral until a higher rpm and then pulls again. but still not at lower rpms the only thing i found to get it to be ok is to pull it down in second back to drive and its fine
has anyone had this problem or might no what it is.
thanks[/align]
Old Nov 23, 2007 | 09:41 PM
nitrous_bob's Avatar
nitrous_bob
Default RE: AODE problem?
ODband is toast , you will need a full rebuild again, the particles contaminate everything, and the other hard parts will all scored from the od band not clamping anymore.
it's like it goes into neutral right ? it's dead.
Old Nov 24, 2007 | 05:44 PM
dbiser's Avatar
dbiser
but it doesnt do it all the time just every now and then so that is why i didnt think it was real major just hoping maybe a sensor or something
thanks
Old Nov 24, 2007 | 11:11 PM
c4king's Avatar
c4king
it can be a number of things overdrive servo, band, clutches, has the transmission ever blew fluid out the vent or dip stick?
Old Nov 24, 2007 | 11:14 PM
03BottleFedGT's Avatar
03BottleFedGT
been there done that. time for a rebuild overdrive band is gone
Old Nov 24, 2007 | 11:16 PM
nitrous_bob
ORIGINAL: 5pnt0gt
thank you
i only reply when i KNOW i'm right
Old Nov 27, 2007 | 11:14 AM
dbiser's Avatar
dbiser
no it never blow any fluid out
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
