oil pressure
oil pressure
hey i have a 1990 5.0 it has about 165k i noticed when i was racing a lil import i was going about 95 in fourth and like 4500 rpm and i look at my gauges and my oil pressure was reading zero so i backed off imediatly and wen i slowed down to like 60 at 3000 rpm i had pressure again you think the oil pump is going bad and if so it sucks becouse i dont feel like pulling the motor to do it comments would be great
RE: oil pressure
if your oil pressure really did go to 0 at 95 in fourth you may have to pull the motor.....and put a new one in. that motor is moving fairly fast at 95 in fourth not to get any oil. i would just start saving your money so when your oil pump does fail you can get a new engine.
one thing that will help your motor is not to race anymore, especialy those ricers
RE: oil pressure
before pulling anything off..go get a mechanical test gauge for test purposes and make sure your getting the same symptoms to occur on the mechanical gauge that you did on your stock gauge...if you do then it'll be a internal pressure problem...one thing to check are the galley plugs that are pressed in under the timing cover one of them is for the lifter bores...under high r's mine would loose pressure and then at an idle return to normal...turns out one of the plugs blew out racing[:@]....anyway perform the above stated test before doing any work to make sure you have the problem narrowed down to a pump
RE: oil pressure
well i wanna just redo the bottom end becouse i redid the stock heads for now and brought them back to specs but i wanna do like eagle rods and better forged pistons and bore it .30 over just wondering wat you guys would recomend for a decent 12 second all motor bottom end
RE: oil pressure
well it's not just in the bottom end or engine...you'll need supporting mods like gears suspension mods and exhaust and headers just a few things to mention.........but here's what I had and ran 12.20's easily.........92 roller cam block bored .030 , forged I beam rods, .200 dome kb pistons with afr 185's = 11 to 1 compression.....xe 282 hr cam....565/574.....rpm air gap intake , 650 carb, full length headers, bottom end balanced, aluminum flywheel, elec fan and elec water pump, roller rockers...ect ect.. and the list goes on but that's the base block build and bolt ons...you'll need some cam, heads, and good flat top forged pistons, and a good intake and roller rockers to start and most of all know how to drive your ace off down the 1320!!!!
RE: oil pressure
Have you checked your oil level? If you're running low then at higher rpm the pump is moving more oil than is being returned, and the pickup is running dry. Definately check with a real gauge first though.
RE: oil pressure
no five quarts and i got suspension air bags and frame conectors mickey thompson drag radials i was thinknig a 351 but i wanna get the best lower end and a cam i wanna get the twisted wedge heads later this winter
RE: oil pressure
is it a highflow oil pump?
either way go buy a mech guage... i trusted my stocker... and ended up w a siezed pump and two thrown rods... whole time guage read that i was fine as far as oil pressure goes
i now have a mechanical one going on the car... i just dont know where to mount it
