CHeck Engine
Does anyone know y wen i go 3,000 rpms or higher the "check enigne" comes up for i about 30 sec then turns off. i change my oil regularly so i'm thinkin that its something more. i plan to get the engine timing checked.
ORIGINAL: 94 Casper 5.0
The check engin light comes on when the EFI system get a reading from a sensor that is out of spec . if the timeing is out it wont throw a light . get a scan tool from auto zone $15.00 . read the directions its easy look up the codes replace the bad sensor . light goes out . But read the directions thare is more to the test than just pluging in the tool , rev engin , turn weel , pump brake . if your going to run EFI you havto know how to do this test . the car will tell you what is wrong you just hafto know how to get it to talk to you
