Power steering pump ?
Old Dec 13, 2007 | 08:41 PM
Gpony's Avatar
Gpony
Default Power steering pump ?
Im replacing the power steeing pump,it wasnt working when i bought the car. Where are the lines that go to the pump(any pics would help) they werent hooked up.
Old Dec 13, 2007 | 08:44 PM
dillon1340's Avatar
dillon1340
Default RE: Power steering pump ?
there's only two lines, the low pressure and the high pressure. low pressure held on with clamp high pressure screws in. were the lines taken off and are no longer there? because if they are there they only go into pump one way. i can take pics of mine if you need it.
Old Dec 13, 2007 | 08:48 PM
Gpony's Avatar
Gpony
nothin was hooked up,id appriciate the pics when ever you get the time.the only disconnected hose is ripped and goes to the radiator thing behind the radiator.
thanx
Old Dec 13, 2007 | 08:56 PM
dillon1340's Avatar
dillon1340
i went and looked at mine. 89 lx. there are two fitting next to lower driverside radiator that the power steering lines go into. the one from bottom of pump goes to the lower fitting and the one threaded into the pump goes to the top fitting.
Old Dec 13, 2007 | 09:16 PM
Gpony's Avatar
Gpony
Ok,i went and looked at those fittings next to the radiator,the top one had a hose and was zipped tied under the battery box and the other one had a hose but was ripped up.
now i gota get some hose and a clamp and i should be good,thanx 4 taking the time to look,i owe you one
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
9550
Oct 26, 2015 05:01 PM
uberstang1
Sep 20, 2015 06:42 PM
rksnow1
Sep 14, 2015 08:46 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
