RUSTED FRAME RAIL
I have a 90 notch. On the drivers side the frame rail that runs underneath the shock tower in the front is starting to rot away pretty bad can this be fixed? The car looks great and i have alot of time and money in it...... Please help.
My reccomendation is this:
Any GOOD welder can fix this problem, essentially, all you really have to do is cut away the bad metal, grind down the surfaces, and weld in new metal. make sure the welder will contact ford about the type of steel used for the frame rail, and also, make sure the welder is certified. depending on the condition of the car, you could probably get a welder to do it for a few hundred bucks, and cost of the materials.
-kevin
-kevin
mrappe
Sep 26, 2015 10:16 AM
Sep 17, 2015 07:57 PM
