trans problems
Old Dec 16, 2007 | 03:47 PM
silver91gt's Avatar
silver91gt
Default trans problems
well. i made a big mistake today on my t-5 rebuild, I was putting the shifter block thing, and forgot I left the old roll pin inside the hole, and put a new one on top of it, now the freakin roll pins are holding it in place.
now is my only option to drill out the roll pins? or is there some way of getting them out?
I feel so stupid now.
Old Dec 16, 2007 | 04:08 PM
HACKGT350's Avatar
HACKGT350
Default RE: trans problems
just take a punch and push them out and you should be fine
Old Dec 16, 2007 | 04:43 PM
silver91gt's Avatar
silver91gt
its inside the trans already, the botom one is pressed all the way through to the plate, and the other one is pushed halfway down the shifter shaft
Old Dec 16, 2007 | 05:25 PM
silver91gt's Avatar
silver91gt
guess ill need some strong drill bits, im not sure if roll pins are hardend or not
Old Dec 16, 2007 | 06:44 PM
silver91gt's Avatar
silver91gt
bump
Old Dec 16, 2007 | 10:42 PM
silver91gt's Avatar
silver91gt
ttt
Old Dec 18, 2007 | 08:15 AM
silver91gt's Avatar
silver91gt
well since nobody has done this before, heres a tip, make sure you take out all roll pins when working on something with them!
Old Dec 18, 2007 | 01:12 PM
90lxrider's Avatar
90lxrider
yes the only way to get that roll pin out is to drill it.....ive done that b4 also ..........it takes a while...use oil while u are drilling and get a good HSS bit....
mtgldr
Feb 3, 2024 09:00 PM
warwickbass
Sep 20, 2015 04:51 PM
97SN95GT
Sep 13, 2015 09:45 PM
tramphardrocker
Sep 13, 2015 08:56 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
