problems
Old Dec 18, 2007 | 09:14 PM
84conversion50's Avatar
84conversion50
Default problems
got a used motor with about 70k miles on it. dropped it in and got it running. so the problems..
low oil pressure. at idle at 10-12. when you start driving it goes up to 30-33 when you get on it and 22 when normal driving. is this a problem? my other motor had 60lbs+
other problem is when i time it to 10degrees like the specs call for it does not want to stay running. but at 22 it idles great but backfires like a fully auto shotgun.
Old Dec 18, 2007 | 09:24 PM
95vertGTS's Avatar
95vertGTS
Default RE: problems
try setting everything to TDC, resetting the dizzy,and then setting timing to 12* or so
Old Dec 18, 2007 | 09:29 PM
84conversion50
it dont want to start then itll just turn and sometimes try to kick. im wondering if im 180 off but i cant check till the morning
Old Dec 18, 2007 | 09:43 PM
mx07gt's Avatar
mx07gt
with the engine running....take the oil cap off... does air sputter out?
Old Dec 18, 2007 | 09:46 PM
84conversion50
there is a hole that t's off on the oil cap. dont know what it was for but its just open now. what would it mean if air did sputter out
Old Dec 18, 2007 | 10:20 PM
84conversion50
nm duh itd be blow by but why would that cause that?
Old Dec 18, 2007 | 11:37 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
ORIGINAL: 84conversion50
22 for a base timing setting is = too much..set to spec and if it won't idle make sure dizzy is not a tooth off or two and if it won't idle then try adjusting the carb
Old Dec 18, 2007 | 11:40 PM
84conversion50
it wont start at all at 12. but would that cause low oil pressure also? or is that low
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
