blinker problem flasher?
Old Dec 23, 2007 | 05:46 PM
89mustangfive0's Avatar
89mustangfive0
Default blinker problem flasher?
ok i posted up a problem with my blinkers in my 90gt. i hooked up a power probe and everythngs good so i just need a flasher, problem is i cant find the wire to where the flasher goes the flasher for the hazard lights are in the fuse panel but i need the wire for the blinkers?? is it beind the glove box? helpp
Old Dec 23, 2007 | 05:56 PM
fourfivefour's Avatar
fourfivefour
Default RE: blinker problem flasher?
It's behind the center of the dash attached to the support bracket.
Old Dec 23, 2007 | 06:22 PM
1fastzook's Avatar
1fastzook
Yes it behind the glove box up and to the left
Old Dec 23, 2007 | 08:00 PM
89mustangfive0
thank you i will go check it out tomorrow and let you know what happends
Old Dec 24, 2007 | 03:14 PM
holyshift's Avatar
holyshift
I had the same problem 2 years ago, I replaced the flasher and everything and nothing would work. What I found was that in your steering column there is a plug type deal, and it must control everything from ignition to the turn signal switch. I found mine was loose. Its right by were you would put your key into your ignition. Fixed all my issues.
Old Dec 24, 2007 | 05:16 PM
dillon1340's Avatar
dillon1340
ORIGINAL: holyshift
yep. ignition switch fixed my stuff too. took a while to figure that one out.
Old Dec 24, 2007 | 06:51 PM
ttocs's Avatar
ttocs
the hazard switch has a tendency to get dirty since the collect so much dust at the top of the steering colum. Try pushing the switch in and out a bunch of times and see if the problem goes away.
Old Dec 26, 2007 | 01:34 PM
bbbngowc's Avatar
bbbngowc
ORIGINAL: 89mustangfive0
Problem fixed? Enquiring minds want to know.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
