when hoisting up the engine should i....
Old Jan 11, 2008 | 03:49 PM
five0fm's Avatar
five0fm
Default when hoisting up the engine should i....
should i unbolt the engine from the mounts or unbolt the mounts from the frame. im just using a cherry picker to pick the engine up a pit to get the pan and pump off..
Old Jan 11, 2008 | 03:52 PM
ALMOST STOCK's Avatar
ALMOST STOCK
Default RE: when hoisting up the engine should i....
I've always gone with unbolting the mounts from the frame.
Old Jan 11, 2008 | 03:53 PM
BLK89GT's Avatar
BLK89GT
frame it is so much easier
Old Jan 11, 2008 | 03:54 PM
five0fm's Avatar
five0fm
thanks guys, frame it is...back to work
Old Jan 11, 2008 | 03:58 PM
ALMOST STOCK
Have Fun!
Old Jan 11, 2008 | 04:11 PM
jagman454's Avatar
jagman454
yea do frame, when I pulled mine I took off the mounts from the engine (first and last time doing that) it was a pain to line up all the bolts again when I put it back in, so yea, unblot from frame, not engine.
Old Jan 11, 2008 | 04:21 PM
blwn93gt's Avatar
blwn93gt
have fun with the oil pan and oil pump project. i just did min last sunday and it was a lot of fun. youll have less of a headache if you unbolt the steering rack from the k member and let it drop a little. it also gets a little tricky putting everything back together.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
