Engine ID problems
Old Jan 12, 2008 | 08:32 PM
PFCAiello's Avatar
PFCAiello
Default Engine ID problems
I recently bought a 302 from a reputable salvage yard, i was told it was a 1985 M code 5.0 HO, but im not so sure gor the reason that it has the crappy tin can chrome valve covers on it, and came with cast iron manifolds, but it did come third hand out of a wrangler, how could i find out if it is an 85 4V HO?
Old Jan 12, 2008 | 09:01 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: Engine ID problems
look at the casting numbers on the block..I have a 85 4v h.o in my garage an I can tell you...also pulling the intake and it should have the spyder bar to retain roller lifters and a aluminum 4 barrel intake
Old Jan 12, 2008 | 09:10 PM
PFCAiello's Avatar
PFCAiello
thamks...im most worried that its a original CFI or non-Roller HO, and i cant tell what intake it had since i bought it with a performer intake manifold and a holley truck avenger carb. Did the CFI's have the same heads?
Old Jan 12, 2008 | 09:52 PM
mjr46's Avatar
mjr46
I can't remeber what my 85 cfi stang had for heads but they sucked....if it was a cfi motor..it'll be a non roller motor and casting number on the block will be different..get a casting number and I may be able to help you
Old Jan 12, 2008 | 09:56 PM
PFCAiello's Avatar
PFCAiello
Yeah im having my mechanic check it asap and isnt the dizzy gear different?
Old Jan 12, 2008 | 10:06 PM
mjr46's Avatar
mjr46
ORIGINAL: PFCAiello
the roller block uses a steel gear for the dizzy where as the non roller block will use a cast iron gear......but unless they are using the stock ignition and at this point it won't matter cause someone has been there before and no telling what parts they mixed and matched or if they even have the right dizzy gear mated to the cam
Old Jan 12, 2008 | 10:13 PM
PFCAiello's Avatar
PFCAiello
Is there any way of telling if its a HO specificly, not just a Non-HO roller block?
Old Jan 12, 2008 | 10:17 PM
mjr46's Avatar
mjr46
casting number and see if it has a roller cam...it should have a e5 casting number on the block if it's a true 85 roller block...in 87 the casting went to a e7
Old Jan 12, 2008 | 10:18 PM
PFCAiello's Avatar
PFCAiello
thank you man...ill get the number as soon as i finf it
Old Jan 14, 2008 | 01:44 PM
PFCAiello's Avatar
PFCAiello
ok the casting number is E5AE-C3B-5C6
