Ford Crate Engine
im looking at a crate engine to do come this fall or next year since ive racked some series miles on my engine and it seems more economical then a rebuild...
its listed on blueovalindustries.com as this http://www.blueovalindustries.com/pr...p?pid=99011377
its the Ford Racing 302 GT-40 Crate Engine 345 HP ford item number M-6007-XB3M
has anyone had any experience with this engine, if i throw on a typhoon intake with 70mm throttle body and use my exisiting cai and shorty headers is it still going to be a) streetable as a daily driver and b) does 350 seem like a reasonable horsepower output
with intake, tb, egr spacer, the crate engine, and reusing my existing water pump, alternator, p/s pump and smog pump and either the ac condensor or a delete kit its about 5,500.00, does that seem worth it...?
thanks for any and all help, as always
NA
NA
if your gonna spend 5500 do this!!
http://fordstrokers.com/index.php?target=cart
and you'll still have 2000 left over to play with and make tons more power than the ford crate motor
I have that Ford B-cam crate motor in my '65 fastback that I have converted to EFI. Of course, you'll be able to find other motors out there that generate more power and/or cost less. That said, the Ford Racing motors are great motors with all new components at a pretty good price IMO. BTW, you can get that motor from Summit Racing for $4059 with shipping about $125. I had mine delivered two days after ordering it.
http://store.summitracing.com/partde...p;autoview=sku
If streetability is your thing, you may want to get the E-cam motor instead, especially if you have an automatic. No offense to the other guys who posted above, but I wouldn't go with either a supercharger or 347 for a daily driver. The Ford Racing motor will put out enough power to get you in trouble while remaining streetable at the same time.
BTW, the motor comes with a brand new reverse rotation water pump, fox body oil pan and dipstick and nifty polished Motorsport valve covers. FWIW, I'm using an Explorer intake, Accufab 70mm TB, 24# injectors and a 77mm Pro-M MAF with an A9L computer. Works great!
Good luck!
Jeff
Good luck!
Jeff
ORIGINAL: mjr46
Jeff
5.0/342 GT-40 ALUMINUM HEAD FORD RACING PERFORMANCE CRATE ENGINE
M-6007-X342*
342 cubic inch
HP to be determined
lb.-ft. of torque to be determined
10.0:1 compression ratio (nominal)
Hypereutectic pistons
Forged steel cap screw connecting rods
Hydraulic roller camshaft M-6250-X303 with .542" lift intake and exhaust, duration at .050" is 224 degrees intake and exhaust
Double roller timing chain M-6268-A302
Nodular iron crankshaft
Rear sump pan fits most Fox body cars
MSD billet distributor
Ford Racing aluminum GT-40 cylinder heads M-6049-X303 with 1.94" intake valves and 1.54" exhaust valves
Roller rocker arms M-6564-B351
Single plane “Victor Jr.†intake manifold M-9424-D302
New block, oil and water pumps, oil pan, steel billet flywheel and harmonic balancer
Can be used in kit cars, street rods, Mustangs, Fox-bodied cars, and trucks
Depending on your application, the timing cover and/or water pump, damper, oil pan and pickup tube may need to be reused from your original engine
12 month, 12,000 mile warranty
$5295 - In Stock
sean hyland motor sports...if your looking for a "ford racing" crate engine with a warranty.
M-6007-X342*
342 cubic inch
HP to be determined
$5295 - In Stock
ORIGINAL: gothand
I know that people speak very highly of that place from what I've seen. To be clear, what would be the true cost to get the motor to the same level of finish as the Ford Racing motor (i.e. everything but the intake manifold)? I could be wrong, but it looks like you could easily spend well over $4000 to get to finish up the long block, correct? In addition to the balancer, the Ford motor also includes a new flywheel.
Jeff
ORIGINAL: mjr46
Jeff
ORIGINAL: JBradley500
M-6007-X342*
342 cubic inch
HP to be determined
$5295 - In Stock
M-6007-X342*
342 cubic inch
HP to be determined
$5295 - In Stock
i saw this one actually and thought about it, but i dont remember, does it come with the whole efi set up, or was that the 347 that efi wont clear the valve covers??
when i say daily driver i mean something that can handle about 700 miles a week, because thats what i do, and preferbly run on 87 or 89 octane, looking for 350+ power.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
inyadreems
Aug 21, 2015 09:10 AM
