MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   5.0L (1979-1995) Mustang (https://mustangforums.com/forum/5-0l-1979-1995-mustang-14/)
-   -   engine guru's inside!!!! (https://mustangforums.com/forum/5-0l-1979-1995-mustang/400937-engine-gurus-inside.html)
nmerrill Jan 31, 2008 04:49 PM
Well, I got the motor all together. Everything is buttoned up, and I stabbed teh distributor. I tried turning it over, and nothing. It just spun. The engine would not fire. I tried moving the dizzy around, stabbing it again, everything. I trieed timing it for 4 hours today, and I got nowhere. The motor didnt even try to stumble. I could smell lots of raw fuel, but I checked the spark and it looks good, firing order is right, plugs are new, I cannot figure this out for the life of me. I am pulling my hair out. Does anyone have any ideas?? FYI the motor is a TF HCI combo, s-trim, and all supporting mods.
my77stang Jan 31, 2008 04:55 PM
RE: engine guru's inside!!!!
hmm...
even @ 180 deg. out or with the wrong firing order on the distributor it will backfire and pop and crap.
if the injectors were pulsing at the wrong time it would still have fuel in it from pulsing and should still wanna run to some degree i would think.
are the valves adjusted too tight? maybe they aren't closing all the way? did you install the cam 180 deg out?
f*ck dude, i dunno what else to come up?
nmerrill Jan 31, 2008 04:58 PM
I was wondering if valve adjustment would cause a problem. I turned 3/4 turn past zero lash. Would that be too tight? About the cam, I installed it dot to dot. How could I have screwed that up?
lxman1 Jan 31, 2008 04:58 PM
Try a compression test first. Cam 180 out?
nmerrill Jan 31, 2008 05:01 PM
Could compression be bad? I just put new head gaskets on, and ARP bolts. Even with bad compression wouldnt the engine at least stumble?
Joel5.0 Jan 31, 2008 05:32 PM
How to Solve an EFI NO START
nmerrill Jan 31, 2008 05:51 PM
ORIGINAL: Joel5.0
Thank you, I will run through those tomorrow. How weak would the spark have to be to not fire?
Joel5.0 Jan 31, 2008 06:23 PM
You could have good spark at the spark plug wires, but since it has a raw fuel smell, need to also check the plugs are not fuel fouled.
tooslow5.0 Jan 31, 2008 06:27 PM
ORIGINAL: my77stang
hmm...
thats the first thing i thought, that would mean zero compressionand explain the fuel smell. try loosening up the rockers and see if it starts to run.
my77stang Jan 31, 2008 06:41 PM
i always went 1/2 turn and never had a problem. it would be fairly easy to crack them loose one at a time and back off 1/4 turn then tighten up the poly-lock
© 2026 MH Sub I, LLC dba Internet Brands
