speed density any good????
Old Feb 1, 2008 | 10:50 PM
justintx75's Avatar
justintx75
Default speed density any good????
i am looking at purchasing a 87 gt 5 speeed with the sd set up and was wanting to know the pro's and con's of it. is it worth having and are there any serious issues and limitations. how hard is it to convert over to mass air oris the sd good enough? I am not looking to do any major mods just simple bolt ons like headers and exhaust.
Old Feb 1, 2008 | 10:52 PM
AdderMk2's Avatar
AdderMk2
Banned
Default RE: speed density any good????
you can do everything.... dont listen to anyone who says SD is a limitation
because its not
Old Feb 1, 2008 | 11:13 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
SD is not bad but without a special tuner like lets say...a MEGASQUIRT...........CAM CHOICES will be limited or idle surge will be your companion but can easily be tuned out and from what I have studied on the megasquirt system sd will not be a limitation as that's what it's for and it's a fairly affordable system..you just have to learn what all the scaller tables are for and by changing the values in them what does it control/affect
Old Feb 1, 2008 | 11:25 PM
justintx75's Avatar
justintx75
so if i dont mess with a cam change the sd is a good over all system for a daily beater with high milage?
Old Feb 1, 2008 | 11:38 PM
mjr46's Avatar
mjr46
oh heck if you don't plan so mod it..SD is just fine.. no need for mass air and with sd you can even change intake and heads but anymore than a mild cam heads and intake and you'll be pushing the 19 lbs injectors to the limit expecially if you put NOS on top of that...at that point you'd start to need a possible tuner..but for DD and a beater sd will be fine
Old Feb 2, 2008 | 12:08 AM
dimebag's Avatar
dimebag
stay SD... trust me...when it comes time to mod it, pm me
Old Feb 2, 2008 | 01:49 AM
67mustang302's Avatar
67mustang302
You can change cams with SD, but with the stock system you have to be thoughtful in your selection of a cam so as to avoid certain problems. Going to an aftermarket setup can allow you to choose as radical a cam you want depending on the system. Some systems use alpha-n at an rpm you set, so it only looks at throttle position and rpm under the pre set rpm. That way you don't have the vacuum associated issues with idling a radical cam on SD.
Old Feb 2, 2008 | 08:11 AM
justintx75's Avatar
justintx75
ok thanks for the info, is there any thing different about a car for califorina??
Old Feb 2, 2008 | 08:27 AM
mjr46's Avatar
mjr46
^^^^^^a californis model 5.0 in 88 and up would be mass air equipped but 87 cali model should be speed density
Old Feb 2, 2008 | 08:49 AM
justintx75's Avatar
justintx75
how do you tell the difference when looking under the hood? i was reading this tech and it says that 87,88 cali cars are mass air
https://mustangforums.com/m_1853287/tm.htm
