TPS way off!!!
Old Feb 2, 2008 | 02:32 PM
tmuti13's Avatar
tmuti13
Default TPS way off!!!
I just checked my TPS and the voltage was .76. I drilled the holes widerand got it to 1.00 V, but I'm wondering what damage, if any was done while the TPS was jacked up?
Old Feb 2, 2008 | 02:37 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: TPS way off!!!
what prob are you having ..cause in theroy according to the factory spec the tps can be set to i believe .75 to .95... people just like to set it between .93 to .99...which is a optimal setting ..it shouldn't of caused to much of a prob
Old Feb 2, 2008 | 03:07 PM
tmuti13's Avatar
tmuti13
the only problem i'm having is on cold starts, the car will start and then stall out anywhere from 3-7 times until it will finally stay on. or, if i give it gas to keep the rpms high for a few seconds, it will stay on. Also, the car failed NOX (i am running hi flow cats)
Here is a list of what I've done so far:
Plugs & WIres
cap & rotor
pcv & screen
clean egr & replaced gasket
clean IAC
clean MAF
clean TB
replace emmissions tubing (some tubes were cut in half) on the passenger side - drivers side looks ok
replaced AIR upper check valve (there was a hole in it)
fuel filter
of course when i started the car up after adjusting the TPS, it stayed on since the car was already started earlier. when i drive the car, it doesn't feel like its starving for fuel. I have pretty good power throughout the RPM band. Any ideas?
Old Feb 2, 2008 | 03:12 PM
Joel5.0's Avatar
Joel5.0
DIY KOEO/KOER/Cylinder Balance Self-Test
Old Feb 2, 2008 | 04:17 PM
Hung Like a Stang's Avatar
Hung Like a Stang
NOx emisisons are caused from excessive heat in the combustion chamber combining oxygen with nitrogen. Usually caused by a lack of EGR or a lean condition.
ShaneB26154
35
Mar 4, 2021 04:05 AM
mirandaandjimmy
Nov 16, 2015 08:51 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
bmorrisj
May 27, 2004 06:18 PM
