19 # injectors
Old Feb 5, 2008 | 02:02 PM
1993 5.0's Avatar
1993 5.0
Default 19 # injectors
When doing an H/C/I swap, should i go ahead and put in some 24# injectors?
Old Feb 5, 2008 | 02:04 PM
hatchdemon89's Avatar
hatchdemon89
Default RE: 19 # injectors
DEPENDS ur better off replacing ur maf housin throttle body first before goin bigger injectors
Old Feb 5, 2008 | 02:05 PM
1993 5.0's Avatar
1993 5.0
have 70mm TB, and 76mm MAF
Old Feb 5, 2008 | 02:11 PM
hatchdemon89
then go for it i run 24's on my 306 with upgraded gt40ps an a f cam go for it u'll notice a big difference also get a fuel pressure regulator so u can adjust the fuel pressure to ur likin
Old Feb 5, 2008 | 02:12 PM
flyinghigh2k8's Avatar
flyinghigh2k8
yea its a good idea to bump up your injectors. What H/C/I are you going with?
Old Feb 5, 2008 | 02:21 PM
1993 5.0's Avatar
1993 5.0
I'm leaning towards the trickflow streetheat top end kit.
Old Feb 5, 2008 | 02:22 PM
1993 5.0's Avatar
1993 5.0
Probably should update the fuel pump too right?
Old Feb 5, 2008 | 02:23 PM
1993 5.0's Avatar
1993 5.0
Do you know what kind of power #'s you are putting down?
Old Feb 5, 2008 | 02:26 PM
hatchdemon89
Trick flow waste of money go with some afr heads or better yet get a nice set of gt40's with a goodlift up like mine 550lift custom cam stroke the block an spray it or dont but u will push real good #'s out of that i would say what im pushin but noone would belive me on here with my setup
Old Feb 5, 2008 | 02:35 PM
hatchdemon89
fuel pump yeah replace go with a walboro 255 thats wat i got
