question
Old Feb 18, 2008 | 09:01 PM
steve r's Avatar
steve r
Default question
I found out that my car was a 4 cyl conversion but I never knew ituntilI ran a car fax on it....Are there any parts that are weaker like for example the steering....I am scared to do anything with it hard becuase I am scared somethings going to break becuase it was a four cyl. at one time.
Old Feb 18, 2008 | 09:56 PM
Stevens91gt's Avatar
Stevens91gt
Default RE: question
it should be fine
i mean as long as it's bolted down [8D]
Old Feb 18, 2008 | 10:13 PM
Liquid_02's Avatar
Liquid_02
Only differences between them are the springs, rear-end, tranny, and rear-end. If your car was done properly, all of them should have been changed. Steering is the same.
Old Feb 18, 2008 | 10:17 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
the 5.0 will have a closer ratio steering gear = not a problem....and springs will be softer on 4 cyl = not a prob.. and do a burn out!! one leg or two?? still won't be a prob..the 7.5 will handle the power and the tranny...most likely has the 5.0 tranny and even if it had the 4 cyl 5 speed ..it'll hold up.. been there done that...so quit worrying and beat on her!!! to fun
Old Feb 20, 2008 | 07:06 AM
steve r's Avatar
steve r
it has a whole new suspension...eibach springs and adjustable shocks...it has the 8.8 rear end with 373s..and it has the t5 tranny..I just wanted to know if there is anything else.....those are some pictures, I couldnt even tell it was a 4 cyl conversion
http://i127.photobucket.com/albums/p...rrr/car007.jpg
http://i127.photobucket.com/albums/p...rrr/car006.jpg
http://i127.photobucket.com/albums/p...r/car002-2.jpg
http://i127.photobucket.com/albums/p...r/car002-1.jpg
Old Feb 20, 2008 | 01:12 PM
87Stallion's Avatar
87Stallion
Looks good to me.
Old Feb 20, 2008 | 02:48 PM
mjr46's Avatar
mjr46
don't worry about it..car looks fine.. run the **** outta it!!
Old Feb 20, 2008 | 05:24 PM
Projectquick's Avatar
Projectquick
Like everybody has told you, you have all the necessities to make it a 5.0 car so it should be fine. The one thing you might want to look into upgrading if its still stock is the brake system. Even on GTs they are a little on the scrawny side.
Old Feb 20, 2008 | 07:34 PM
mustangcobra94's Avatar
mustangcobra94
nice looking car man!
Old Feb 20, 2008 | 07:58 PM
bbbngowc's Avatar
bbbngowc
ORIGINAL: Projectquick
Not to hijack the thread. What are the recommendations to upgrading the brake system?
