Is it an AOD or AODE...Please help
Old Feb 23, 2008 | 12:23 PM
verter2's Avatar
verter2
Default Is it an AOD or AODE...Please help
My wife's 93' Triple White LE has a code T for the trans, which according to Chilton's says it is an AOD. But, it does not list a code for an AODE which were in use at the time. The way this transmission shifts (quickly shifting through the gears-no wind out) I seems like it's an AODE. Chilton does list a A4LD trans code, could this be the AODE at that time. Was the AODE used in 93 Stangs? I want to put in a valve body to get better shifts, using more of the gearsand need to know just which one I have. Thanks in advance for any help.
Old Feb 23, 2008 | 12:26 PM
OneFine89Mustang's Avatar
OneFine89Mustang
Default RE: Is it an AOD or AODE...Please help
92 was the last year for the aod..you must have an aode
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
up to 93 = AOD 94 and up = aode = electronic auto overdrive
94Yellow50's Avatar
94Yellow50
so long as no ones changed it out..93 was aod....94-95 were aod-E...
damn im slow or sumthin..when i clicked reply there were not..when it shows up..theres 2 already lol
Old Feb 23, 2008 | 12:36 PM
verter2's Avatar
verter2
Thanks for the help guys. Your input makes sense with the codes that I am looking at. It must be an AOD, but have to wonder why it shifts so quickly, where as my 91 vert AOD likes to wind out the gears a bit, and shifts great. They both have shift kits, but the 93 was rebuilt. Think maybe the rebuild was done poorly? What could someone screw up that would make it shift through gears to fast?
Old Feb 23, 2008 | 12:42 PM
94Yellow50's Avatar
94Yellow50
ive never had to work on a 93 auto..but isnt there a linkage that can be adjusted for your problem...if not..then ive learned somethin..but i thought i remember readin about it..
Old Feb 23, 2008 | 12:47 PM
mjr46's Avatar
mjr46
check the throttle valve/kickdown cable/rod adjustment
Old Feb 23, 2008 | 12:51 PM
verter2's Avatar
verter2
mjr46, where can I find what the proper setting for the cable/rod is? And whould that being out of adjustment affect how quickly the trans shifts from 1st to 2nd to 3rd? Thanks
Old Feb 23, 2008 | 12:54 PM
Cobra77's Avatar
Cobra77
http://youtube.com/watch?v=6L3hNzxdiYw
The TV cable is what controls your shift points. The slightest bit of adjustment can change them a lot.
94Yellow50's Avatar
94Yellow50
haha..thats what i was trying to remember lol...
