e brake dont work
Old Feb 23, 2008 | 04:34 PM
89stanger1989's Avatar
89stanger1989
Default e brake dont work
its connected right but has to much slack and doesnt work. how do you fix this? its a 89
Old Feb 23, 2008 | 04:39 PM
94Yellow50's Avatar
94Yellow50
Default RE: e brake dont work
well on my 94 where the cable comes down from the handle and splits to the two separate cables for each side..it was connected with a bracket that had a nut to adjust how much tension the handle side had...try lookin underneath..idk if urs will be the same setup tho..being 5 years older..
Old Feb 23, 2008 | 05:25 PM
89stanger1989
yea i got that. i'm going under to see if i can tighten it. thanks
Old Feb 23, 2008 | 05:43 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
if you have drum brakes on the rear..make sure that the cables which are connected to the parking brake arm on the back side shoe is not froozen or siezed..also inspect condition of brake shoes and self adjusters are not froozen up
Old Feb 23, 2008 | 06:48 PM
telsonman's Avatar
telsonman
also, check to make sure that the rear brakes don't need to be changed. My e brake didn't hold crap. I always had to leave it in first when parking on a hill, and crank up on the e brake as much as it would go. I tightened the cable to its max and still had the same problem. I put it new shoes in the rear and voila, good as new.
Old Feb 23, 2008 | 08:45 PM
89stanger1989
yea i just tighten them and it didnt help. time to check out the back
Old Feb 23, 2008 | 09:19 PM
foxxjnm's Avatar
foxxjnm
If you figure it please post I have the same problem with my '93.
MustangGirl98
Aug 2, 2016 08:10 AM
CarrieS
Sep 1, 2015 01:00 PM
Fast-Hands
Aug 19, 2015 06:54 AM
cvarner131
Aug 17, 2015 07:38 AM
FD725
Aug 11, 2015 03:43 AM
