Timing problems
Old Feb 25, 2008 | 10:16 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Default Timing problems
I got to run my car for the first time at night and noticed my headers start glowingwhile just sitting at idle for a few minsand the timing at 10 degrees. I know that means that the timing is off and when I hook up the vac advance on the dizzy it starts running really ruff and backfires. I checked with a light while it was doing this and it was hitting way past the 30 degree mark and my base timing is set at 10 degrees.
I didn't put this motor together nore do I know the guy who did but I am thinking the cam gear was set off a tooth for more torque because the motor used to be in a muddin bronco. I was told it has some aftermarket cam so that gives me the idea that they played with the cam timing. Tomorrow I am gonna back the timing way down to see if that helps out at all. It runs pretty good without the advance hooked up but after I do put that line on it runs like ***.
What do you guys think? I am going to bed and will check back in the morning.
Thanks
Old Feb 25, 2008 | 10:22 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: Timing problems
restab dizzy it's most likely got the timing off!!
djbigskrilla
Sep 20, 2022 01:04 AM
Cin K
Aug 31, 2015 07:31 AM
stormesixx
Aug 25, 2015 09:11 AM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
