rear 5-lug conversion kit?
Rear
To convert the rear end to 5-lugs you need to replace the 4-lug axles and drums with 5-lug units. The axles that are needed will be either off of a Ranger, Bronco II or Aerostar van.
From an '83 to '92 4 cylinder or 3.0L V6 Ranger/Bronco II with a 7.5" rear end you will need two driver's side axles. Only the driver's side will work as the pumpkin on these rear ends is offset and the axles are different lengths (you need the longer of the two axles). It should measure 29-5/32".
From an Aerostar you will need two of the passenger side axles from an 86 to 97 model.
The axles are all the same so they can be mix-matched (i.e. - one driver's side axle from a Ranger and one passenger side axle from an Aerostar).
You can use the brake drums from either side of the above listed vehicles but make sure that they are 9" drums. The 4.0L Rangers came with an 8.8" rear end with 10" drums - these will not work.
Prices will vary, of course, but I was able to get the axles and drums from a local "Pull It Yourself" type yard. The axles run about $20 each and the drums will run about $15 each.
Be sure to check the axles to make sure they are not bent or worn on the bearing surface and check the drums to ensure that they are smooth or can be turned to no more than the maximum diameter.
Miscellaneous items for the rear include new brake shoes, fresh gear oil, RTV gasket maker to seal the differential cover and one additional lug nut for each side.
http://www.stangnet.com/tech/lug.html
50resto has a kit, ebay has some kits to.
Its cheaper to do a junkyard pull of the axels, call around to your local junkyards and see if they have the axels. Then just go to napa or something and pick up new drums and shoes. Thats what i did, saved me like 130$ over 50resto
Nov 10, 2015 11:39 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
