Leaking MLS head gasket?
Old Mar 6, 2008 | 05:55 PM
68EFIvert's Avatar
68EFIvert
Default Leaking MLS head gasket?
Well I completed the blower conversion and had it tuned. When I picked it up from the tuner he said I had a fluid leak and it was coming from the back of the engine. He thought it was a heater hose or something. I thought it was really weird since the hoses are new. I suspected it was the head gaskets leaking.
Fast forward 2 weeks to today. I stopped by the body shop to check on progress and there was a bunch of antifreeze on the ground under the car. I felt the back of the engine and there is fluid by the heads and block. I think it may be my Mr. Gasket MLS head gaskets. I am wondering if my junk yard 5.0 block did not have as straight of a deck as the machine shop thought when I had them bore it and check it out.
I can think of a couple options.
1) take the heads off and replace the MLS gaskets with FelPro 1011-1.
2) take off the upper intake and valve covers to see if retorqueing the bolts fixes the problem.
Do any of you guys have experience with MLS gaskets and if so can you give me some advice? I went with them because of the blower. I am running about 10 lbs of boost and the AFR guy said the FelPro 1011-1s would be good up to 12 lbs.
Old Mar 6, 2008 | 06:51 PM
my77stang's Avatar
my77stang
Default RE: Leaking MLS head gasket?
could be the intake gasket on the back of the heads......
but......
why in the hell would you use an MLS gasket with a blower and NOT get the block milled?
Old Mar 6, 2008 | 08:06 PM
68EFIvert's Avatar
68EFIvert
I never planned on the blower when I had the machine work done 2 years ago. You know how it progresses with these things. I looked at it another time and noticed a plug on the flat portion of the block behind the intake. It is threaded but does not have a plug. It was filled with antifreeze. Maybe my problem is simple and I need to plug this? Do you guys know what that hole is for/goes to? Thanks for the help.
Old Mar 6, 2008 | 08:21 PM
silver91gt's Avatar
silver91gt
mls gaskets require the heads and block to be a certain smoothness
Old Mar 6, 2008 | 10:31 PM
my77stang's Avatar
my77stang
yeah mls gaskets need a finer deck surface but usually by the time a block has been tore down, wire wheeled, sanded on, or anything else the smoothness is there..... its the fact that the deck surface isnt flat thats the problem.
our shop decked every single block for every motor we build (stock replacement motors mostly) and they were always warped. less than the heads usually were, but always warped. i know this because i've decked hundreds of blocks myself.
Old Mar 6, 2008 | 10:36 PM
68EFIvert's Avatar
68EFIvert
Well it looks like I am going to pressure check the system to confirm my theory but it sounds like it is right. It looks like I know what I will be doing this weekend. S&%T!!!!
Old Mar 6, 2008 | 10:58 PM
aode08's Avatar
aode08
check your oil, make sure your not running coolant in the block.
Old Mar 7, 2008 | 01:02 AM
67mustang302's Avatar
67mustang302
Cometic makes a nice head gasket.
Old Mar 7, 2008 | 12:38 PM
only90s's Avatar
only90s
ORIGINAL: 67mustang302
True, but my Cometic MLS still seep a tiny bit....Cometic told me to run Radiator Sealer through my engine to stop it [sm=boosign.gif]....
Old Mar 7, 2008 | 03:33 PM
uedlose's Avatar
uedlose
I run the Fel-Pro mls on my wifes car it dont leak water but it leaks oil some at the heads. I run the Cometics on a customers car no leaks yet but I did put stop leak in the rad.
Dathan
Oct 5, 2015 05:52 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
NYstang
Sep 30, 2015 09:56 PM
wraith777
Sep 28, 2015 10:49 AM
Sep 27, 2015 03:16 PM
