timing problem...pings
Old Mar 7, 2008 | 12:26 PM
PFCAiello's Avatar
PFCAiello
Default timing problem...pings
ok just installed a new motor...but when you set the timing to above 0 degrees it pings hell of bad. im pretty sure its bone stock....whats likley to be the problem?
Old Mar 7, 2008 | 01:27 PM
cholericfc's Avatar
cholericfc
Default RE: timing problem...pings
ok I just went through installing a crate motor - this is what u need to do - in order ot prevent headaches:
1.) Find out if you have the right computer by calling Ford and comparing numbers off the unit if ur car has one
2.) #1 cylinder needs to be top dead center or right before it (I think its a 15/16 socket for the crank pulley)
3.) verify correct firing order 3 times.
4.) You HAVE TO do a idle setting procedure from Ford, in order to get it running right.
5.) a timing light to set at 10-14 degrees, maybe 16, depending on the kind of driving ur doing.
Old Mar 10, 2008 | 03:09 PM
PFCAiello's Avatar
PFCAiello
thanks. the firing order is correct...idle's ****. it's a 84 stnd lifter Crown Vic/LtD motor, used a 50 oz flexplate, my car's old carb intake fuel pump dizzy etc...im using 89 octane fuel.
Old Mar 10, 2008 | 11:14 PM
silver91gt's Avatar
silver91gt
ORIGINAL: PFCAiello
if you set it lower than 0 it will fire when the piston is still coming up which will break something rather quick.
1-5-4-2-6-3-7-8 should be the firing order you need, and the distributor rotates counterclockwise
the rotor should be pointed almost straight back when you put the distributor in with the #1 piston at TDC.
how old is the balancer, the outer part could have turned a little bit giving you false readings.
mungodrums
Oct 7, 2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
Sep 28, 2015 09:18 PM
StalkerGT
Sep 25, 2015 02:41 PM
Sep 8, 2015 11:50 AM
