Question about compression testing.
I just bought a compression tester and did some tests. i did cylinders 5 through 8 right now and before i go on i have to know something.
when i cranked the engine over a couple times the reading on say, cylinder 5, reads 85 psi. then if i crank it again it goes up to 125 psi. which is the correct reading?
Yes you should crank the motor for 3 revolutions, you might not have had a good seal on the tester the 1st time. I usually do each cylinder about 3 times for repeatability.
thanks for the info dude, alls i know is that if i keep cranking it my compression will sit at about 140 psi. i was worried this wasnt right but i guess it is, and 140 is great right??!!
Stock heads? Should be around there I think 160psi equates to like 10:1 compression if memory serves. What you are really after is uniformity between cylinders, no more that 2 to 5% difference between them.
