Lost compression
Old Mar 13, 2008 | 04:11 AM
fearce65's Avatar
fearce65
Default Lost compression
I know someone who has a "jasper engine" in his 5.0LX. He has had problems with smoke since he had the engine put in his car. Now, 3 years later, he found out that there is no "compression" in #8 cylinder. What should he do? And if it is worth it, should I buy it?
Old Mar 13, 2008 | 04:58 AM
86GT 93LX's Avatar
86GT 93LX
Default RE: Lost compression
i wouldnt,whats the comp on the one cylinder thats bad?
Old Mar 13, 2008 | 05:39 AM
Rajun_Cajun's Avatar
Rajun_Cajun
I smell a ring job coming...
Old Mar 13, 2008 | 08:51 AM
WhiteWindsor's Avatar
WhiteWindsor
My guess is you dropped a valve. If that happened then there is a good possibility that the piston may have come up and slapped the valve causing piston damage. But you need to take the head off to be sure.
Old Mar 13, 2008 | 08:04 PM
aode08's Avatar
aode08
First lesson, avoid Jasper Engines, I have found some with oversize pistons in a few bores, the rest standard. And the pistons and rings cleaned very well to look good, and they just throw in bearings.
Your better off rebuilding what you have or a used one, and doing it slow and the right way.
They shortcut alot.[:'(]
Old Mar 13, 2008 | 08:53 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
if it has no compression...it's gonna have to come apart but it's repairable..if you can do the work yourself.. that's a huge plus!!!
Old Mar 18, 2008 | 04:05 AM
fearce65's Avatar
fearce65
It's basically, what I told him. Rebuild it, or get rid of it. He's looking to rebuild.
Old Mar 18, 2008 | 08:35 AM
aode08's Avatar
aode08
if its just one cylinder, he may of dropped a valve, or carbon, is preventing the valve from sealing or a piece of gasket or rtv from the lower intake.
Pull the intakes off, and if you have a shop vac, as you put it on the runners, you can tell if its the head thats the issue, or if you got to go down low.
It will make the noise, just like putting your hand on the vac
Old Mar 18, 2008 | 09:41 AM
my77stang's Avatar
my77stang
thats sad, cause jasper USED to make some of the best stock replacement reman engines you could buy
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
foxdude
Sep 24, 2015 08:45 PM
bconboy
Sep 21, 2015 12:52 PM
uberstang1
Sep 20, 2015 06:42 PM
