TPS problem still
Old Apr 8, 2005 | 04:17 PM
stanglx2002's Avatar
stanglx2002
Default RE: TPS problem still
i was wondering since i put in a 331 stroker in my car is that the problem im having with the TPS bc of the dramic increase in airflow with the new engine and the computer is fixing itself. Im just guessing and also to fix this is to get a chip isnt it. If i do what chip should i get that can be changed if i add more mods to the car?
Old Apr 8, 2005 | 10:39 PM
Trannyman's Avatar
Trannyman
It seems to me that you are getting reference voltage on the signal wire. This tells me that you have a short to power. Unplugged, it should be zero. The signal wire is sending voltage back to the PCM. This lets the PCM know how much throttle you are giving it and how fast. Have you traced the wire back? Physically trace the wire back into the harness. Make sure the insulation isn't cracked and making contact with the ref. voltage wire. Check for pinched wires (freshly installed engine or trans, it can happen).
Old Apr 8, 2005 | 10:54 PM
silver91gt's Avatar
silver91gt
mabye you have the sensor installed backwards?
this is the only thing I can think of.
the wires should point toward the back of the car.
other than that, is your throttle open when you check it?
you should set the idle first, with the car running, then set the tps with the engine off key on.
you probably know this already though.
mabye ford had a bad batch of tps sensors.
Old Apr 9, 2005 | 12:07 AM
stanglx2002
i know how to set the TPS and the sensor works bc it works on my dads cars so that out of the picture
Old Apr 9, 2005 | 12:11 AM
86HOGT's Avatar
86HOGT
Alright stanglx, then you eliminated a bad TPS basically. It seems trannyman is right on target. There's probably some chafing down the line on the wires, and the 5V reference voltage is shorting to the return signal wire. See, the computer see's no voltage drop, so it think's it's at WOT, 4.96V. Back probe and find the short to reference voltage.
Old Apr 9, 2005 | 12:14 AM
stanglx2002
k i will check that tom thanks guys i will let you know what happens
Seanam
Oct 4, 2015 10:15 AM
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
