question....with pics....
Old Mar 28, 2008 | 10:54 PM
DoctorD415's Avatar
DoctorD415
Default question....with pics....
Noticed this kind of wierd thing happening the other day, not sure whats goin on. Where i have circled there, coming out of that hose, which i believe has something to do with the heat control inside the car is doing wierd things. Lately if i turn the heat on high, it will push air out of that hose and a liquid of somesort also comes out? Not sure what it is, the liquid seems to be clear? Any idea what that is and why something like this would happen. If i shut the heat off then it stops, but when i turn it on it does this?
[IMG]local://upfiles/76165/FB36026308614FF89E4546D17F41C9AE.jpg[/IMG]
[IMG]local://upfiles/76165/E6E5AA04017A4127AAA7AEC71E994334.jpg[/IMG]
Old Mar 28, 2008 | 11:13 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: question....with pics....
That's the condensate drain for the a/c system. But I see yours is diconnected. Also, coolant will come out of there if the heater core is bad but it won't be clear fluid.
Old Mar 28, 2008 | 11:48 PM
ctgreddy's Avatar
ctgreddy
where'd you get your valve covers from?
i like those ones.
Old Mar 29, 2008 | 07:44 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
ORIGINAL: ctgreddy
i like those ones.
Pro50sc is right and those valve covers are stock on 83-85 5.0 h.0 4v motors
Old Mar 29, 2008 | 09:19 AM
DoctorD415's Avatar
DoctorD415
ya i just painted them
Ya the ac is gone from this car, so is this hose hooked up to anything? Is it linked directly to the heater core?
[IMG]local://upfiles/76165/16EF614B651D4FC68205A1017B228319.jpg[/IMG]
Old Mar 29, 2008 | 09:30 AM
302army187's Avatar
302army187
was it without AC from the factory?
maybe if someone removed the ac, they removed that hose.
Old Mar 29, 2008 | 09:48 AM
DoctorD415's Avatar
DoctorD415
no it was with ac, but the previous owner took it out. I dont think it should be anyhting to be worried about, i think its just water? But should it be blowing air out?
Old Mar 29, 2008 | 10:06 AM
302army187's Avatar
302army187
how much air are we talkin?
if it was alot i might be worryed, but if its not much it prob just how the system works
Old Mar 29, 2008 | 10:13 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Yes some air will blow out. It's directly connected to the heater box. There shouldn't be liquid coming out of it though. Maybe there is a leak from the windsheild or cowling allowing the water inside.
Old Mar 29, 2008 | 01:31 PM
DoctorD415's Avatar
DoctorD415
Well if it were leaking, itd be coolant coming out correct? So if i dont seem be be loosing coolant overall then it wont be leaking, so ill just keep my eye on the level of coolant.
gafireman
Apr 5, 2010 02:45 PM
07VistaChicago
15
Mar 18, 2010 08:19 PM
Shaunmac9128
Chop Shop
12
Feb 15, 2010 03:17 PM
gothamems
Jul 4, 2008 07:53 PM
