MSD 6AL
Old Apr 5, 2008 | 07:36 PM
Jeff 86 GT's Avatar
Jeff 86 GT
Default MSD 6AL
I just installed an msd 6al ignition box and my tach is not working. Did anyone else have this problem and if so what do i have to hook up.
Old Apr 5, 2008 | 07:42 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: MSD 6AL
Tach, aftermarket or stock?
Old Apr 5, 2008 | 07:55 PM
Jeff 86 GT's Avatar
Jeff 86 GT
Default RE: MSD 6AL
stock tach. i have an autometer tach that i will be installing shortly> So basically what to do with both of them
Old Apr 5, 2008 | 08:05 PM
wrenchturner75's Avatar
wrenchturner75
Default RE: MSD 6AL
6al should have a port on the side of the box, im pretty sure thats where the tach hook up goes.
Old Apr 5, 2008 | 09:38 PM
thunderjet429's Avatar
thunderjet429
Default RE: MSD 6AL
you need the convertor to make it work with a stock tach in that year...... been there done that MSD# 8920 i believe
Old Apr 6, 2008 | 12:04 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: MSD 6AL
It's called a tach adapter and I'm using a msd 6al and stock tach and I have the 8920 adapter..if you want to run the autometer tach... you won't need the adapter and all you have to do is plug the green wire from your autometer tach into the tac port on the 6al box
Old Apr 6, 2008 | 07:54 AM
thunderjet429
Default RE: MSD 6AL
sounds familiar...........
firehorse02
Nov 16, 2015 11:28 AM
mirandaandjimmy
Nov 16, 2015 08:51 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
mustang20010
Dec 10, 2003 08:33 PM
r0ck3r
Dec 3, 2003 06:10 AM
