coolant leak, somewhere
Old Apr 6, 2008 | 12:48 PM
Jenzpony's Avatar
Jenzpony
Default coolant leak, somewhere
My cars leaking coolant from somewhere- I'll top it off, and within a week the low coolant light will come back on. the car isnt overheating...actually, the needle barely moves at all, not even into 'normal'. i know its not a radiator leak. but you can smell it bad sometimes inside the car, and the heat sucks- heater core, maybe?
help a girl out![]
Old Apr 6, 2008 | 01:10 PM
stang8689's Avatar
stang8689
Default RE: coolant leak, somewhere
If your heater core is leaking the passanger floor will be wet, check the thermostat gasket, water pump and timer cover gasket. Sounds to me like a hose might be leaking coolant onto your header and causing it to burn making the smell in the car
Old Apr 6, 2008 | 01:17 PM
ponyponer's Avatar
ponyponer
^ that sounds very well it could be a possibility. i've never had a heater core go in any of my vehicles ever. i do know there is a puddle, and one person i know told me it was wet out of his heating/air vents.
Old Apr 6, 2008 | 01:35 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
most likely a heater core it'll leak out the evaporator drain vent on to the exhaust
Old Apr 6, 2008 | 01:37 PM
ponyponer's Avatar
ponyponer
these seem to be a common repair on these cars. out of everyone i knew well who had one of these only one actually had to replace his. and a lot of the people i knew who had one had close to 150k. i'm sure it will probably go sometime soon on mine though just like everything else.
Old Apr 6, 2008 | 01:46 PM
mjr46's Avatar
mjr46
replaced mine 3 times so far!![:@]
Old Apr 6, 2008 | 02:02 PM
ponyponer's Avatar
ponyponer
now that is worse luck than mine. what were you using for aftermarket ones?
Old Apr 6, 2008 | 02:12 PM
mjr46's Avatar
mjr46
ORIGINAL: ponyponer
first one was factory original, second one was a cheap 11 dollar autozone one[:'(], 3rd one is one from ford made by valeo....it's still in there so hopefully it'll last
Old Apr 6, 2008 | 04:49 PM
NYstang's Avatar
NYstang
MF Staff Snitch
her car has about 140k on it. and it doesnt leak into the interior, that i noticed. heater core, you think?
Old Apr 6, 2008 | 05:05 PM
1mustang's Avatar
1mustang
my heater core just went bad in my 86 and there was no fluid on the floor...it went out the evap drain on the firewall
