Need help!!
Old Apr 7, 2008 | 11:54 PM
reno27's Avatar
reno27
Default Need help!!
Ok i recently took out my ac and powersteering and got a electric water pump and will take out my smog pump when i get my exhaust. Ok my ? is how am i going to run the belt? I was just going to buy a ac eliminator pulley for the ac and a smog pump eliminator pulley. i think i might have to make a bracket to put it where the powersteering went. Can i i just run the belt around the crankshaft pulley,alternator pulley,and belt tensioner pulley and smog? and if i delete the smog can i do just crank alternator and tensioner pulley? or can i get rid of the tensioner and just do crank alternator?
My idea now is to run a ac delete pulley and have every other pulley there except water pump and power steering. idk need some help on routing the belt and getting it together.
lots of pictures would be great
[align=left] [/align]
Old Apr 8, 2008 | 11:19 PM
reno27's Avatar
reno27
Default RE: Need help!!
ttt
Old Apr 9, 2008 | 05:29 AM
FoxGT's Avatar
FoxGT
http://cgi.ebay.com/ebaymotors/Ford-...spagenameZWDVW
http://www.atomicperformance.com/ind...mp;ProdID=1070
They use the alternator as the tensioner rather than the tensioner being on the car. That should work for what you're needing. If you want to look at some different priced ones just google; mustang "alternator tensioner" bracket
You should get quite a few results
Old Apr 9, 2008 | 09:39 AM
reno27's Avatar
reno27
thanks that did help but he still has his power steering and stock water pump?
i got a electric water pump and no power steering and soon no smog pump so do you know how i would go about doing that now?
Old Apr 9, 2008 | 09:43 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
ORIGINAL: reno27
should of got a meziere elec pump with built in idler ten you could run stock config like I did..= easy and no guess work
http://i242.photobucket.com/albums/f...347pics002.jpg
