Air/Fuel Ratio Guage
Old 04-09-2008, 06:34 AM
stang8689
stang8689's Avatar
Default Air/Fuel Ratio Guage
I am looking at an Autometer air/fuel ratio guage #7575. I really have no idea how to hook this up to my 86. I want to make sure i'm not running too lean or rich. Anyone know how to hook one up?
stang8689 is offline
Old 04-09-2008, 07:10 AM
94StinkinLincoln
94StinkinLincoln's Avatar
Default RE: Air/Fuel Ratio Guage
you have to put a bung in the exhaust, like a 02 sensor hole.
94StinkinLincoln is offline
Old 04-09-2008, 07:54 AM
Joel5.0
Joel5.0's Avatar
Aside the lights effect, that gauge will not provide you with the info you may be looking for. It uses the narrowband O2 signal (which is a "switching" type of signal) and it will not tell you the actual A/F lambda value. If you still want to pursue its use though, check the installations instructions at http://www.autometer.com/productPDF/0837L.pdf
A better and more economic alternative is to use the EEC-IV and check how it's working, run a set of DIY KOEO/KOER/Cylinder Balance Self-Test and check if you have any rich/lean failure codes stored.
Joel5.0 is offline
Old 04-09-2008, 09:04 AM
FoxGT
FoxGT's Avatar
x2 on the narrowband only being good for the pretty lights. Better to look into a wideband.
FoxGT is offline
Old 04-09-2008, 01:30 PM
bighungrymatt
bighungrymatt's Avatar
yeah I wouldnt waste money on narrowband
bighungrymatt is offline
Old 04-09-2008, 02:31 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
narrowband FTL
FivePointOhh is offline
Old 04-09-2008, 05:14 PM
stang8689
stang8689's Avatar
So whats a wide band and where do I get one. The link didn't work
Old 04-09-2008, 05:28 PM
stang8689
stang8689's Avatar
I was looking some up and they are about $350 does that sound right
Old 04-09-2008, 05:32 PM
1992lx5.0
1992lx5.0's Avatar
i wired mine in right into the main harness on the passenger side so it reading both o2s, ill get ya the wire color tomorrow
1992lx5.0 is offline
Old 04-09-2008, 08:22 PM
stang8689
stang8689's Avatar
thanks
Quick Reply: Air/Fuel Ratio Guage
