rear end
Old Apr 13, 2008 | 05:11 PM
my94pony's Avatar
my94pony
Default rear end
im going to look at a 8.8 rear end with 3:73 gears on it to replace my 7.5 rear end ... whats the best way to tell if this used rear is any good, i dont wana waste my money on it
Old Apr 13, 2008 | 05:16 PM
WhiteWindsor's Avatar
WhiteWindsor
Default RE: rear end
Take the pumpkin cover off and have a look see.
Old Apr 13, 2008 | 05:21 PM
floodzilla's Avatar
floodzilla
you could always buy a rebuilt one or rebuild it yourself. and like fastblack said, take it apart to look for damage.
Old Apr 13, 2008 | 05:24 PM
my94pony's Avatar
my94pony
yea its only $150 and in order to get a tlock and gears for my 7.5 rear it would be $340 so it sounds nice, how much would someone charge to rebuild it?
Old Apr 13, 2008 | 05:27 PM
my94pony's Avatar
my94pony
so if i get the 8.8 rear end will it go right onto my 1994 v6 or will i have to change some parts??
Old Apr 13, 2008 | 06:13 PM
floodzilla's Avatar
floodzilla
idk, im sure its not a direct fit, but it can be done. id say just go with the gears for your current setup. no guessing
Old Apr 13, 2008 | 06:21 PM
WhiteWindsor
I'm not sure if it's a direct swap. But modifications should be minimal. What car is it goin in. Does it have a 6 or 8 cyl? If it's a six are there plans to swap an 8 cyl in there?
Old Apr 13, 2008 | 06:27 PM
HACKGT350's Avatar
HACKGT350
what year is this rear out of if its from an sn95 then it will be a direct swap they have the same set up
Old Apr 13, 2008 | 07:59 PM
my94pony's Avatar
my94pony
its going into a 1994, not sure what its out of waiting for the guy to call me back, and im not planning a v8 swap i just wanted to get the tlock and 3:73 gears
Old Apr 13, 2008 | 08:44 PM
HACKGT350's Avatar
HACKGT350
if its from a fox its not as wide as your stock one. make sure its out of a sn95 or its not the same but will still fix but i guess its good if you want to put wider wheels on
