CAR LOPES AT IDLE...ONLY SOMETIMES.
Old Apr 18, 2005 | 03:36 AM
87 hatch's Avatar
87 hatch
Default CAR LOPES AT IDLE...ONLY SOMETIMES.
SO, MY CAR DRIVES GREAT. I FIXED ALL THE VACUUM LEAKS AND ADDED NEW TPS AND ALL THE OTHER SH#T THAT HAS TO DO WITH THE IDLE. RAN LIKE CRAP WHEN I BOUGHT IT BUT RUNS LIKE A DREAM NOW...
HERE'S THE PROB. SOMETIMES AND ONLY SOMETIMES WHEN I COME UP TO A STOP LIGHT OR STOP SIGN OR JUST IDLE FOR A FEW MINUTES IT LOPES UP AND DOWN THEN IT WILL EVEN IT SELF OUT AFTER ABOUT 15 LOPES.
WHAT DO YOU THINK COULD BE CAUSING THIS PROBLEM?
OH YA, MY POWER STEERING PUMP IS CONSTANTLY LOUD LIKE ITS LOW ON FLUID EVEN WHEN ITS FULL. I DONT THINK THIS IS THE PROBLEM BUT IF YOU HAVE ANY IDEAS PLEASE HELP.
Old Apr 18, 2005 | 05:02 AM
schwindty's Avatar
schwindty
Default RE: CAR LOPES AT IDLE...ONLY SOMETIMES.
Some dudes run ATF if they are out of Power Steering Fluid, this happened to me once I drained it ran some new fluid and its all good now, if not your pump is going.
Old Apr 18, 2005 | 06:01 PM
87 hatch's Avatar
87 hatch
YA, ILL DO THAT TO TRY AND GET RID OF THE NOISE.
BUT AS FAR AS THE IDLE LOPING, DOES ANYONE HAVE ANY INPUT?
Old Apr 18, 2005 | 06:06 PM
GT350Stang's Avatar
GT350Stang
i think i know what you are talking about. it happened to my 84 and they told me that it was one or two of my valves bairly sticking so i got a head tune up on them and it runs perfect. may want to check into that
Old Apr 18, 2005 | 06:09 PM
StangTangGT's Avatar
StangTangGT
Did you replace the IAC??
Old Apr 18, 2005 | 06:10 PM
GT350Stang's Avatar
GT350Stang
this may sound very dumb but what is an IAC? i have a carb. car so i dont know
Old Apr 18, 2005 | 06:13 PM
StangTangGT
http://www.fordturbo.com/iac.html
its the idle air control sensor
Old Apr 18, 2005 | 06:14 PM
GT350Stang's Avatar
GT350Stang
OOHHHHH i had something like that but then i went with an aftermarket carb. thanks for in info
Old Apr 18, 2005 | 06:16 PM
StangTangGT
yep it says he replaced the TPS but the iac could very well be at fault.
Old Apr 18, 2005 | 06:17 PM
87 hatch's Avatar
87 hatch
ORIGINAL: StangTangGT
YA SURE DID. I REPLACED EVERYTHING THAT HAS TO DO WITH IDLE. THE THING IS, IT RUNS GREAT WITH NO POWER LOSSES. ITS ONLY IF I COME TO A COMPLETE STOP AND LET IT IDLE, ONLY SOMETIMES IT WILL LOPE FOR LIKE 20-30 SECS THEN EVEN ITSELF OUT AND BE TOTALLY FINE UNTIL THE NEXT RANDOM TIME IT HAPPENS.
