smog pump removal
okay i found that a new belt for my car to bypass the smog pump will cost me roughly 24 dollars. Is the gain from doing this actually worth it? What is the actual gain and is it noticeable?
thankx
thankx
the gain was noticeable when i pulled it off of my car, i just plugged up all the vaccuum lines and pulled that hard line off the back of the heads and pluged it as well, seems to run alright
remove the pump and the entire EGR system. its a good 25 lbs total. i removed mine and routed my belt as you can see from my site (if you need more help just PM). its a really easy mod and as i always say, subtracting weight is just as good as adding power. DO IT!!!
ORIGINAL: 94 Casper 5.0
so how do u get your sticker??? sounds kinda shady.
well for one, here in south florida there are no emissions tests. and if you plan on passing emissions id keep the smog system.
