Install Cam, or rebuild Engine first?
Old Apr 19, 2005 | 10:12 PM
FIVE_OH's Avatar
FIVE_OH
I ♥ Acer
Default Install Cam, or rebuild Engine first?
I was thinking of installing a Ford E303 or B303 cam in my '92 Pony.
But, since the engine has about 142,000 miles, can it handle the cam or should I rebuild it first?
Old Apr 19, 2005 | 10:53 PM
LOVEMY88GT's Avatar
LOVEMY88GT
I ♥ Acer
Default RE: Install Cam, or rebuild Engine first?
def rebuild that baby
Old Apr 19, 2005 | 10:57 PM
fordguy17's Avatar
fordguy17
i wouldn't if it runs okay. there is many 5.0's that run past 150k no problem. there are other mods you should do before a cam though.
Old Apr 19, 2005 | 11:07 PM
paulstang's Avatar
paulstang
i would have to say rebuild that way you know everything will work for a while
Old Apr 19, 2005 | 11:33 PM
sastangman's Avatar
sastangman
if you don't have the cash for a complete rebuild,at least
go with a valve job on the heads and new springs..
Old Apr 19, 2005 | 11:39 PM
mkspeed26's Avatar
mkspeed26
i would save up for a while and rebuild it with some performance parts.
Old Apr 20, 2005 | 01:40 AM
fats429's Avatar
fats429
SLOW DOWN GUYS
Look a engin is not a gallon of milk , it does not have a experation date . It ant nothing nore than a cast iron pump . If you have good compression and it does not use to mutch oil ,the olny thing a rebuild will get you is OUT 1000 BUX and right whare you are now
you olny said 142 tall on the clock , that means nothing the shape of a engin is vacum and oil pressure
I sall 302 go as far as 350,000 miles and as little as 35,000 ( god damn mancennie motors) . what kind of shape is the engin in you got to figure that out by doing some basic test . Then you will know what cards you hold
Old Apr 20, 2005 | 01:54 AM
Dan89lx's Avatar
Dan89lx
if the motor is strong, just put the cam in and dont worry about it
Old Apr 20, 2005 | 05:21 AM
tchamber's Avatar
tchamber
I threw on ported (stock) heads, cam, Tbody, MAF and headers/h-pipe at about 110000 miles. When I popped the heads off, I could still see the crosshatch bore marks on the cylinder walls. If you dont see those, don't get a cam. My 2 cents.
Old Apr 20, 2005 | 08:23 AM
86inworks's Avatar
86inworks
just remember this everything has to coordinate in order to make any good power so maybe a rebuild w/ high performance internals and the cam you want, and don't forget you should set it up for what kind of racing or driving style you like...
