Update
Old Apr 26, 2008 | 03:37 PM
PJB's Avatar
PJB
Default Update
Im posting an update on this thread:
https://mustangforums.com/m_4952834/tm.htm
I just swapped out the Cobra computer for the stock A9P (my car used to have an AOD) and the drivability issues seem to have gone away. The stumbling at low rpm is gone and I can drive in the city without a problem now. I drove around a bit and didnt have any issues like before.
Eventually I might get the Cobra MAF but I might just leave the stock computer in since it seems to be running good.
Old Apr 26, 2008 | 03:41 PM
NYMustang50's Avatar
NYMustang50
Default RE: Update
Told ya. Now its up to you. You can leave the stock one in and then just get it tunned or wait and find another cobra mass air and put all the cobra ecu and mass air on and then get it tunned its up to you.
Old Apr 26, 2008 | 03:47 PM
PJB's Avatar
PJB
Default RE: Update
Really I dont think Im going to bother with a tune at this point if it stays running good.
Old Apr 26, 2008 | 05:47 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: Update
cobra maf + cobra ecu +24 lbers = car runs good...any other combo = runs like crap
Old Apr 26, 2008 | 07:59 PM
NYMustang50
Default RE: Update
ORIGINAL: mjr46
Well I think right now hes running
Granatelli MAF sensor calibrated for 24 lb injectors + stock A9P ecu + 24lbers = running great car.
Old Apr 26, 2008 | 10:50 PM
5.0stanger's Avatar
5.0stanger
Default RE: Update
Good, I am glad you got it better. Good luck with it.
Old Apr 27, 2008 | 12:04 AM
mjr46's Avatar
mjr46
Default RE: Update
ORIGINAL: nymustang50
ORIGINAL: mjr46
what I meant was mixing and matching with a cobra ecu = runs like crap...ie...cobra ecu +30b inj +maf calibrated for 30's = run like crap..cause the calibrATION FOR inj is all in the cobra ecu = not forgiving like a fox ecu/a9por a9l...ALL CLEAR NOW????
Old Apr 27, 2008 | 05:57 PM
NYMustang50
Default RE: Update
gotcha sorry mj i get confussed a lot sometimes.
Old Apr 27, 2008 | 06:05 PM
5.0stanger's Avatar
5.0stanger
Default RE: Update
I think the only problem with using a calibrated MAF with the Cobra ECM is the fact that it is alreadyprogramed to run 24's where probably all aftermarket MAFs are calibrated to trick a ECM programed to run 19's. You would most likely need a special MAF or a tune to run a cobra ECM with larger or smaller than 24's.
EZFEED
May 5, 2016 08:54 PM
Kenta08
Sep 2, 2015 10:33 AM
67LimeCoupe
Sep 2, 2015 08:02 AM
movielover40
Aug 27, 2015 10:13 PM
