radiator install
Old Apr 30, 2008 | 08:43 PM
StevoX1's Avatar
StevoX1
Default radiator install
alright so i was gonna order me a new radiator for my 93 5.0 and was thinkin of going with the Summit direct fit aluminum (SUM-380451) and i was wonderin if i can install it myself or if i have to take it in. probably a rookie question, but i'm a rookie.
Old Apr 30, 2008 | 08:45 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: radiator install
It's a pretty simple operation to replace. Not really much to it.
Old Apr 30, 2008 | 09:02 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
I bought the summit aluminum one and it worked great..had to mod the bracket a little but none the less it worked good..in your case the direct fit one will be easy!!
Old Apr 30, 2008 | 09:17 PM
87Stallion's Avatar
87Stallion
probably the easiest thing to do on a fox
Old Apr 30, 2008 | 09:26 PM
bighungrymatt's Avatar
bighungrymatt
I just installed an aluminum radiator on my fox today. Very simple, just had to modify the bracket a little bit.
It was my first time doing it. good luck
Old Apr 30, 2008 | 10:19 PM
StevoX1's Avatar
StevoX1
alright cool so most definetly gona tackle it myself. so am i only gonna need to order the radiator or do i need and compliments for it?
Old Apr 30, 2008 | 10:23 PM
bighungrymatt
You should be fine with just the radiator. I ordered this one on ebay. Used my old overfill bottle.
What thermostat are you running? If its still stock you could always get a Mr gasket 180* thermostat. Thats also very easy to change
Old Apr 30, 2008 | 11:04 PM
StevoX1's Avatar
StevoX1
i believe its 180. i had a coolant leak on the neck so i took it in thinkin it was the gasket but my mechanic opened it up and found the thermo busted!! so the radiator, and overlflow i;m gettin. whats the bracket mod lookin like?
Old Apr 30, 2008 | 11:16 PM
bighungrymatt
there is rubber in between the bracket and the old radiator, just had to slice some of it down. took about a minute to do all 4. but that was with my ebay one...
but I think pretty much with all aftermarket radiators you have to do some modification for the brackets.
Old May 1, 2008 | 12:05 AM
StevoX1's Avatar
StevoX1
alright sweet thanks much
