AOD Problem
So my original problem with my AOD was that after sitting all winter without being run i started it up and drove it more about 40 miles and it wouldn't shift until 3500 rpm. So today i changed the fluid and filter, i filled it with a little over 5 quarts of fluid and that made it worse now it won't shift until 4500 rpm, i added another half a quart and that didn't help either, is this too much or too little fluid or is there something else wrong here? Thanks
well my aode is saposed to take 12.5 quarts but with my smaller converter it only took about 10.
so i'm guessing you need more, not sure if theres that much of a difference between the aod and aode tho.
ORIGINAL: Foxbodyforever
how badly will the tranny be damaged if i over fill it?
Use the dipstick level, with the engine running.
It should only take about 5 quarts when you drop the pan and change the filter. It only takes more if the converter is empty.
Seanam
Oct 4, 2015 10:15 AM
stangin1996gt
Sep 21, 2015 11:01 AM
