Fuel System Help
first you need to decide wat size fuel injectors your gonna put in with the supercharger
or if your plans change 24 lb injectors ideal for h/c/i and misc. bolt ons
than 24 x 8 (number of injectors) = 192 so 190 lph fuel pump would be plenty sufficient... those numbers are coming from a constant max flow rate from each injector which never happens so anything over that would be over kill
use same equation for bigger injectors if you go that route
injector size x8 = ___________
Sep 16, 2015 07:53 PM
Sep 10, 2015 08:39 PM
