adjustable fuel regulator
Old Jun 3, 2008 | 03:58 PM
dukeme's Avatar
dukeme
Default adjustable fuel regulator
Can somebody please give me the correct instructions as how to properly adjust the regulator, I have a BBK...These are my mods:
302 5.0 Ford crate motor
Windsor jr iron heads 58cc ported and polished
Scorpion 1.6 rockers
Mac Shorty equal headers
H pipe into flowmax mufflers
Edelbrock Intake
BBK cold air induction
MSD coil
autolite plugs
JE pistons
forged crank
E303
70 MM Throttle body Edlebrock
24 lb injectors
373 gears
PA C4 transmission
TCI 3500 super street fighter converter
9MM Ford wires
[align=left] [/align]
Old Jun 3, 2008 | 04:07 PM
94StinkinLincoln's Avatar
94StinkinLincoln
Default RE: adjustable fuel regulator
stock fuel pressure is 39 with vaccume off, somewhere around 35 with it on.
Old Jun 4, 2008 | 12:47 PM
dukeme's Avatar
dukeme
[align=left]
ORIGINAL: 94StinkinLincoln
[/align]
Can somebody please give a tad bit more explanation as how to make the adjustments? Thanks.
Old Jun 4, 2008 | 01:14 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
turn the car on
disconnect vac line going to fpr
turn adj. bolt counter clockwise until to desired fp
tighten down locking nut
reconnect vac line
your done!!
Old Jun 4, 2008 | 01:20 PM
5.0 MPG's Avatar
5.0 MPG
if you FPR didnt come with a fuel guage then you'll need to rent one from AZ. once you have it attach it and do as instructed above. there is usually a nut you need to loosen first to turn the hex screw. i wont comment whether or not you need more fuel. it appears that way with your mods, but your best off having it tuned at this point to pull out all the HP from your current mods.
93 LX FiveO's Avatar
93 LX FiveO
medium sized allen wrench
turn it cc to release, opposite to increase
if you havent already, put a gauge on it...
Old Jun 4, 2008 | 01:30 PM
dukeme's Avatar
dukeme
Thanks guys...Appreicate all of your help
baddog671
Jul 26, 2016 01:20 PM
Thunderball
15
Nov 22, 2015 11:49 PM
svfetter
Oct 5, 2015 11:39 AM
mrappe
Sep 26, 2015 10:16 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
