X2P ecu out of 90 t bird HO is this compatible?
the number on it is F2MF-12A650-RA
but for some reason on the other side of the connector it says E9AF 14A624 AA.
SO I DONT KNOW IF ITS a recal ecu or what but it came out of a 1990 5.o ho tbird i want to know if i can use it for mass air. the car had mass air on it
do u know what the differances are adder? im having issues with my idle sounding like i have a cam running the a9l ecu in my 86 with my egr bloced off and smog pump blocked of and not connected. im stumped, i cant find a vac leak
ORIGINAL: AdderMk2
you dont still have the map sensor connected... do you?
so how come a 5.0 ho t bird motor in a 90 is differant? is it just sensors and stuff?
F2MF = a '92 EEC and '91-'93 T-Bird EECs do not use a BP sensor. It was the first generation of the CBAZA or SN95 EEC type..... or not GUFB MAF (A9x) compatible.
ORIGINAL: Joel5.0
so this ecu would work on a 5.0 if it had everything switched over to whats on a sn95 or 91-93 t bird? this makes no sense cus a 1990 t bird is supposed to have the right ecu and if the door tag says 7/90 its a 90
A9L = '89-'93 Mustang/Manual
X2P = '91-'93 T-Bird/Auto
X2P is a load based strategy EEC with datastream capabilities, or the precursor of the CBAZA setup used for SN95's, it does not use a BP sensor + its pinout is different to the A9x GUFB setups. Make a comparison between both types using the table at http://fordfuelinjection.com/5.0Lpinouts.html .
