Ordered pullies, now kinda scared!!!
Old Jun 10, 2008 | 09:06 PM
5.0 85 GT's Avatar
5.0 85 GT
Default Ordered pullies, now kinda scared!!!
I just ordered pullies from Brothers Performance out of my MM&FF mag, and they were on sale for 70 bucks for the 3 piece aluminum ones.
Its the cranksahft, water pump and alt pullies. I just watche da vid on the install, and says i need ot torque the crankshaft to specificationsa nd make sur eits on right or i will have major issues, is this true? what is the best way to isntlal these? has anyone done it? any prep help?? thansk guys, i hope htis wasnt a bad buy!
Old Jun 10, 2008 | 09:09 PM
fordboyyfm's Avatar
fordboyyfm
Default RE: Ordered pullies, now kinda scared!!!
just put locktite on the bolts holding the puley on.
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Torque=tight. Done. It's not a big deal to do. 4 bolts hold the crank pulley on, thighten them down evenly and tight. 4 bolts hold the w/p pulley on. Leave the alt pulley alone. It will cause you to have charging issues. This should help ya
http://www.marchperf.com/superford1.html
Old Jun 10, 2008 | 09:10 PM
93 LX FiveO's Avatar
93 LX FiveO
yup the big bolt in the middle of the crank pulley is a PITA to remove.
if you have power tools, you will be all set.
otherwise, you will need a large pry bar or torque wrench.
i used a torque wrench, and positioned it that so when i crank the motor over, it would rest against the floor and force it loose. remember to disconnect the coil first.
need any help let me know.
Old Jun 10, 2008 | 09:11 PM
5.0 85 GT's Avatar
5.0 85 GT
sorry for my terrible spelling, this keyboard sucks, the video said i needed some rtv oil to seal the crankshaft pulley, they did the pulleys on a 01 gt, so diff then mine obv, but are you sure you should just tighten the hell out fo the crankshaft one? thats what i am worried about, and i wont put the alt one on then, ive heard bad things about it on 5.0's...
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
just tighten them down..if you get the rachet at the right angle you can get them fairly tight without the crankshaft moving
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: 93 LX FiveO
That bolt does NOT have to be removed and the coil does not need to be disconnected. [&:]
Old Jun 10, 2008 | 09:12 PM
5.0 85 GT's Avatar
5.0 85 GT
disconnect what coil???
Old Jun 10, 2008 | 09:15 PM
mjr46's Avatar
mjr46
^^just do what PRO' said.. the 15/16 bolt does not come out for UD pulley install!!
Old Jun 10, 2008 | 09:17 PM
Maxwelhse's Avatar
Maxwelhse
Dude, just ignore everything said in this thread other than what Pro and MJR added. 4 bolts, add lock-tite, re-install and tighten bolts evenly. That's it. Genuinely a 15 minute swap... Maybe 20 counting the time to put the belt back on.
