got tips????
Old Apr 29, 2005 | 10:01 PM
91lxstang's Avatar
91lxstang
Default got tips????
i just bought a 1991 lx 5.0 and i now im strapped for money.....but i was wonderin how i could improve the performance (hp) of the car for as cheap as possible now.....then later on add things like a supercharger and all that......anyone have any ideas??
Old Apr 29, 2005 | 10:06 PM
jpirate's Avatar
jpirate
Default RE: got tips????
A hypertech chip helps,and one of the biggest improvements in acceleration is installing bigger gears in the rearend.
Old Apr 29, 2005 | 10:10 PM
Chris C's Avatar
Chris C
If its bone stock take out the air intake silencer. Its worth a few HP and its free. Also bump your timming also free but you will need 93 gas so its not really free in the long run.
Old Apr 30, 2005 | 12:29 AM
Dbeck002's Avatar
Dbeck002
I ♥ Acer
ORIGINAL: 91lxstang
Power = Money
how fast do you want to go?
Old Apr 30, 2005 | 01:36 AM
91LXstanger's Avatar
91LXstanger
Cold air intake, gears, electric fan. A good first couple mods.
Old Apr 30, 2005 | 05:04 AM
luckythirteen13's Avatar
luckythirteen13
you could steal a supercharger, that would be free. id do gears. its not free but youll get a huge gain for the amount of money you spend
Old May 2, 2005 | 12:43 AM
91lxstang's Avatar
91lxstang
i also have another question.....im going to put new exhaust on it too but i was wonderin what would sound the best.......i want it to be loud but sound good ..... anyone have any ideas for what i want....i want the loudest best sounding exhaust out there........so i can wake up my neighbors lol
Old May 2, 2005 | 01:09 AM
doobs's Avatar
doobs
a great sounding exhaust i think that isn't very expensive is flowmasters. not extremely loud but sound great. Most of the cars we have in our collection have flowmasters. as for the whole package headers/etc im not quite sure
Old May 2, 2005 | 01:14 AM
GT350Stang's Avatar
GT350Stang
BBK longlubes (for the loudness) and BBK off-road X-pipe (for the performance) and orignal 40's flow (for sound and performance) with dumps (makes it loud and deep sounding and cheaper
Old May 3, 2005 | 01:46 AM
birdman076's Avatar
birdman076
Pull the air silencer in the fender and bump the timing as mentioned, put a lower temp thermostat in ( this will make the car run richer and use more gas but it also bumps the timing too), put the car on a diet. You can go as far as taking the insulation out from under the carpet but I wouldn't do it (heat and excessive road noise suck). Anything your not using take it out of the car, and don't date heavy women they slow the car down lol.
Since its a new car to you, go through the basics, lube the chassis, check tire inflation as they can cause excess friction which will slow your car down. Also better control from properly inflated tires, change the oil ( you don't know exactly when it was changed last). Change the tranny fluid, and gear lube as well. Again not so much for speed but for durability, reliability, and reduce frictional loss. You could move the battery to the rear of the car for better weight transfer, box the control arms fair cheap for better traction. Subframe connectors are another fairly cheap mod, as are poly bushings. These are more for durability or traction rather than going fast, but if you get the car to hook really well then you are using the full potential of the motor to move the car which equates to faster times.
FivePointToTheOh
Mar 9, 2020 10:26 PM
Roxon68
Mar 17, 2016 08:13 PM
Gene K
Oct 21, 2015 11:37 PM
Sep 10, 2015 08:39 PM
