control arm bushings
Old Jun 17, 2008 | 07:37 PM
biggmac's Avatar
biggmac
Default RE: control arm bushings
Thanks, Im going to do this with the rear end in the car,so its probably gonna me a PITA
Old Jun 17, 2008 | 07:39 PM
biggmac's Avatar
biggmac
ORIGINAL: primetime5.0
ORIGINAL: biggmac
So its just easyier and quicker to buy new control arms with the bushing in ....
not true, the bushing is in the axle itself not the control arm, with the research ive done people have said with poly's it causes the rear end to bind up when put in the axle.. i went with OEM bushings myself
Thats what i thought,so ill just install bushings
Old Jun 17, 2008 | 07:43 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: redpony88
just get the weight jackers like i did on my fox, they allow a -1 through + 2 adjustment, i loved my rear cont arms
He's asking about the bushings in the rear not what control arms to use.
I used the stock bushings in mine and bought the tool from Max Motorsports. Made it a lot easier to do.
Old Jun 17, 2008 | 10:08 PM
silver91gt's Avatar
silver91gt
I've done it twice now, and the only way I could get the old rotted ones out was to drill lots of holes in the rubber then pry out the metal insert, and pry the rest out.
Old Jun 17, 2008 | 10:38 PM
biggmac's Avatar
biggmac
ORIGINAL: PRO50SC
ORIGINAL: redpony88
So whats the Bad with the poyls ?
Old Jun 17, 2008 | 10:41 PM
biggmac's Avatar
biggmac
ORIGINAL: biggmac
I read that they say to Grease the bushing before install.......mabey for that reason of binding
Old Jun 17, 2008 | 10:43 PM
biggmac's Avatar
biggmac
ORIGINAL: silver91gt
So how did your car ride before you needed to replace?Did you have that clunking/play in the rear when you step on and off the gas fast
mrtrodonet
Sep 19, 2020 03:12 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
ChampInSD
Oct 2, 2015 04:55 AM
UrS4
Sep 30, 2015 10:13 AM
