Simple Question
Old Jun 17, 2008 | 07:58 PM
whitestang86's Avatar
whitestang86
Default Simple Question
I had put in a MR. Gasket high performance 180 stat and when i'm goin down the road my car only runs at 160. I do have underdrive pulleysbut that shouldn't effectmy temp like that while driving.Should i go back to just a normal 180 stat instead of this high performaceone?
Old Jun 17, 2008 | 08:01 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Simple Question
I will say that the Mr. G stats DO run colder than what they are rated at.
Old Jun 17, 2008 | 08:06 PM
droptop302's Avatar
droptop302
192 is stock T/stat.. I have a 180 in my car but i heard something about open loop/closed loop?
Old Jun 17, 2008 | 08:08 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: droptop302
So is there a point to your statement. I mean it's random. Do you know what it actually means?
Old Jun 17, 2008 | 08:18 PM
whitestang86
i know it doesn't hurt to run cooler, just more fuel consumption when just driving around under normal driving conditions.
Old Jun 17, 2008 | 08:25 PM
droptop302's Avatar
droptop302
ORIGINAL: PRO50SC
Is it bad to run cold... Or to use a 180 T/stat?
Old Jun 17, 2008 | 08:26 PM
93 LX FiveO's Avatar
93 LX FiveO
i know its obvious.. but are you positive it's a 180?
i run a 180 ($6 no brand) with a very big electric fan and aluminum radiator and the temp still reaches 190-ish in traffic.
and yes the computer has closed loop (which runs off pre-set integers) and open loop (which runs off sensor readings.. 02's.. coolant temp.. etc..)
Old Jun 17, 2008 | 08:35 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: 93 LX FiveO
I had the same issue. I ran a 180 but the car would still run anywhere from 195 to 210. Too warm for my liking. I put a 180 Mr Gasket in mine w/ some water wetter and now it runs between 160-175. That's what I wanted. It's a blower car so I want as cool a temp as I can get and still be as efficient as it can, if that's possible.
Droptop, yes if it runs too cold, you will burn more gas as it will take longer to reach closed loop.
Old Jun 17, 2008 | 09:07 PM
whitestang86
yeah i know for sure that it was a 180 stat in mine, just wasn't sure why that stat doesn't keep it at 180 or so, but from what you said pro50 i can understand why it runs cooler since they are suppose to run cooler than rated
Old Jun 17, 2008 | 09:08 PM
OnyxCobra's Avatar
OnyxCobra
ORIGINAL: PRO50SC
i believe this is because Mr G stats are fully open by their rated temp instead of just opening at the rated temp like other stats.
chrisdbassplayer
Oct 13, 2015 06:53 PM
treesloth
Sep 28, 2015 07:03 AM
Ipaman
Sep 22, 2015 07:01 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
