Need help engine codes
Old Jun 21, 2008 | 01:33 PM
89Ford's Avatar
89Ford
Default Need help engine codes
memory codes:
33 - EGR valve closed/erratic or has insufficient flow
53 - Throttle Position Sensor voltage is too high
KOER codes:
12 - Cannot control RPM during self check Idle Speed Control Problem
23 - Throttle Position Sensor is out of range
11 - System Pass?
Old Jun 21, 2008 | 01:50 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: Need help engine codes
ORIGINAL: 89Ford
memory codes:
KOER codes:
11 - System Pass?
if you still have egr and not deleted it then the code 33 could indicate a few things= possible bad egr sensor or valve is stuck closed....or the egr ports/exhaust cross over in the heads/intake are plugged with carbon......easy way to test egr is apply vaccum to valve while car is running and see if motor begins to run rough or die..as for the tps sensor ...you'd need a multimeter to check the vref circuit on it and make sure there is a ref voltage of no more than 5 v present then prob the signal return and monitir the voltage sweep while slowly opening the throttle and look for any opens or shorts to ground....or simply replace the tps sensor and set it to .75 to .99 volts and be done with it and clear codes and rerun koer test...as for idle speed prob......are you having idle issues??
Old Jun 21, 2008 | 02:00 PM
89Ford's Avatar
89Ford
yea it idles around 2,000
Old Jun 21, 2008 | 03:05 PM
89Ford's Avatar
89Ford
ORIGINAL: mjr46
ORIGINAL: 89Ford
memory codes:
KOER codes:
11 - System Pass?
how do I set the volts on the TPS
Old Jun 21, 2008 | 03:06 PM
89Ford's Avatar
89Ford
I just replaced the TPS and scanned again came up with this.
KOEO And Memory Codes:
11 - System Pass?
KOER codes:
91 - Exhaust Gas Oxygen Indicates system lean bank 2 or fuel pressure out of range or fuel control circuit failure
Old Jun 21, 2008 | 04:03 PM
mjr46's Avatar
mjr46
ORIGINAL: 89Ford
11 - System Pass?
KOER codes:
if you have an idle issue that high ..sounds like the Iac pintle is either stuck or the IAC has failed either try cleaning it and or replace it and make sure the Iac passage on the intake is free and clean of carbon..do that and rerun test and see if idle can then be controlled as for lean condition...make sure there are no exhaust leaks on bank 2 before o2 sensor= drivers side..if none exist try replacing o2 sensor for a quick fix..and rerun test
Old Jun 21, 2008 | 05:08 PM
89Ford's Avatar
89Ford
I actually have an exhaust leak pretty bad, i just replaced the passanger side rear tire and i noticed the muffler is crushed. A few weeks ago I hit a man hole on a road that was being torn up and it caused the leak, but I didnt even notice the extent of the damage b/c I stopped driving it.
I replaced the TPS (still didnt really set it to the correct voltage but I played with it till is sounded good) and it no longer idles at 2,000 its at 1,000. Still have the same codes but now I know I need a new exhaust.
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
zanemoseley
Sep 6, 2015 12:58 PM
zachary1988
Sep 4, 2015 03:04 PM
